Home > My Defender > Rear wiper |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
You’ll need to change the wiring on the back door to match the chassis loom - you need a 2002-> rear door loom.
These incorporate a relay onto the back door, which starts and parks the wiper. The relay is triggered from a switched earth, from the dash wiper switch. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
1st Oct 2024 7:21am |
Green 200tdi Member Since: 30 Sep 2024 Location: Wiltshire Posts: 4 |
Thank you 😊
It’s ok there is no wiring in the rear door no wiper motor either 😂 So comes thu chassis loom Is it possible I’ve got a wrong chassis loom as I’ve not seen any extra plugs other then what would be td5 electric fuel pump (not used on mine as I’ve a 200 tdi) Any idea of wire colours I’d need on chassis loom? Thank you. |
1st Oct 2024 4:38pm |
You are looking for a 6 pin connector with 5 wires used:
White/green, black, black/green, white/black, green/purple. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
1st Oct 2024 4:54pm |
last question promise what amp wire from battery to td5 heater plug relay? need to go from battery to relay then relay to plugs. |
1st Oct 2024 8:14pm |
