![]() | Home > General & Technical (L663) > Emergency towing P400e |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2953 ![]() ![]() |
Are you not able to fit a good battery and select neutral in the normal way?
CincyRovers1 Member Since: 30 Nov 2023 Location: Cincinnati, Ohio Posts: 112 ![]() ![]() |
Here's a video from Simon at Powerful UK on how to put newer Defenders into neutral. my 2021 110 S P300 has the physical cable.
๐๐๐๐ ๐๐๐๐๐ง๐๐๐ซ ๐๐๐ ๐ ๐๐๐๐ (Pangea Green over Acorn/Lunar) ๐๐๐๐ ๐๐จ๐ซ๐ฌ๐๐ก๐ ๐๐๐๐๐ง ๐ (Dolomite Silver over Black/Bordeaux Red) ๐๐๐๐ ๐๐ข๐ฌ๐๐จ๐ฏ๐๐ซ๐ฒ ๐๐๐ ๐๐ฎ๐ฑ๐ฎ๐ซ๐ฒ ๐๐ข๐ (Aintree Green over Vintage Tan/Ebony) - Gone ๐๐๐๐ ๐๐๐ ๐๐๐ ๐.๐ (Ipanema Sand over Almond/Arabica) - Gone |
o-ren-ishii Member Since: 25 Jul 2023 Location: The Hague Posts: 40 ![]() ![]() |
Thanks. And thanks for sharing yours has the mentioned โneutral override โ lever.
Mine (2023 75th p400e hybrid) doesnโt have. Iโm aware of the electronic procedure. But Iโm looking for one to put the car in neutral without power. Some people think the blue bolt on the side of the gearbox, displayed on the picture i posted might be an override but I havenโt found somebody to confirm yet. |
My post was ignored. l assume that my suggestion was not viable or there was some other reason why it wouldn't work.
hi lightning, i didn't meant to ignore your reply of course. Because - like I stated in my start post - I had no battery left after the incident ( it was completely flat) that was not an option. "the normal way" for emergency towing is a series of "commands" pushing the throttle down and releasing in a specific order. If you want to know I can look it up for your. Just to clarify that's different to the "everyday" neutral. If you would/could select N with the gear shifter it will default back to park after 10 minutes, resulting in disaster when towing obviously.
I still hope to find out the function of the bolt to the side of gearbox, but since im still traveling (about 16000 km to get back home) I couldn't yet put it on the bridge and try it for myself. Unfortunately I havent found anyone who could confirm (or deny) the manual override possibility. |
