Home > Maintenance & Modifications > reversing camera location
hoover
Hi Im looking to fit my 110 with a reversing camera.
I have read various suggestions that mounting the camera above the door or on the roof rack (where I was going to put it) is not a great idea as they get filthy and somewhere by the number plate might be better.
Does anybody have any suggestions or experience of the best / worst location.?
Thank you Freelander 2 Flora
200tdi 90 1985 (Not Defender) Rhubarb
Puma 110 5 door Twinkle
Post #1046855 26th Sep 2024 9:19am
excossack
I have mine mounted inside, attached to the high level brake light 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1046857 26th Sep 2024 9:21am
andy63
I have a twin camera set up on mine and would agree that the view from the reversing camera is not great..it really needs to be a few feet higher to give a good picture and clear details of where the back edges of the bumpers are..
I get a great view of my spare wheel 😂..but at least a good idea of clearance directly behind the vehicle..
To be fair I only fitted this twin camera system as I had it from me motorhome days..excellent on a big coach built but a bit ott on a defender..
Post #1046858 26th Sep 2024 9:27am
I have two, one in the rear number plate light pointing backwards and one on the rear edge of the roof rack pointing downwards. The latter is by far the most useful.
Both get covered with crud due to the shape of the vehicle, but I have just got in the habit of wiping them whenever I walk past. to get in or out.
Post #1046859 26th Sep 2024 9:32am
Stacey007
Hello
I fitted one to the rear number plate holder as I didn't want to drill any holes. I did this around 7 years ago and its been great, Its slightly off set. However I could still hook up a trailer on my own or get very close in parking gaps.
Since I did this optmil I think it is produce a alloy plinth with the camera built in Smile
Location
Plinth if you want it pre done / alloy
https://www.lrparts.net/da8862-lrc1643-def...LCEALw_wcB
Mines a £10 camera and its been fitted years, in all weather and works a treat Smile
Post #1046860 26th Sep 2024 9:39am
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
I found when looking that there isnt many good positions for a camera so i drilled a small hole and used the rear cross member bolts. Gives a perfect reverse view
[/img]
Post #1046861 26th Sep 2024 10:20am
Mines in the washer jet location, with the washer jet relocated to the side.
Does everything from there except for viewing tow hitch, for that a second cam might be better and you can put a video switch in for that as well.
Mines a Parkvision from Amazon, I’m pleased with the quality of it.
The Optimil number plate light cam is good so I hear, but don’t forget to use a QUALITY video cable.
Stinger do a good one. Thumbs Up WeWillWin🇬🇧🇺🇸
Post #1046863 26th Sep 2024 10:28am
Dinnu
Fitted a camera like this on the number plate light plinth. Used existing holes for the light wiring to get the cables inside the vehicle. Since it is oblique view, its hard to align the vehicle with a trailer using just the camera, but thats what the mirrors are for 😂
On the plus side, very easy to judge distance.
 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1046870 26th Sep 2024 11:57am
hoover
[/img]
Hi I like this, not something I had thought of, nice one. Freelander 2 Flora
Post #1046875 26th Sep 2024 12:53pm
This is a very neat solution. Thumbs Up
Post #1046876 26th Sep 2024 1:15pm
nosnibod
United Kingdom 1998 Defender 110 300 Tdi SW Bronze Green
Ian at IRB did this for me - together with another camera under the number plate plinth, selected via a discrete switch on the steering wheel cowling.
 Dave
Green Goddess - 1998 Defender 110 300tdi
Post #1046877 26th Sep 2024 1:26pm
Zed
I have the Optimill. It’s a neat solution but the camera is about as budget as you can find and in my case didn’t benefit from better cables. It’s fine for my purposes and I think it looks lovely but if one needed a decent camera built in I would suggest buying one separately and replacing. I don’t blame Optimill though, they obviously had to make it to a price. If they did include a quality camera it may have put the unit out of reach for the customer.
Originally I had a camera in my NAS step which I thought was amazing at the time. Unfortunately in wet weather it got covered in muck instantly making it useless. WARNING.
Post #1046889 26th Sep 2024 3:03pm
Alitaff
I fitted a reversing camera to the center of the rear crossmember and to protect it fitted a home made cover above it using the existing nuts.
Post #1046929 26th Sep 2024 10:06pm
That is neat.
Some of them can be pretty rubbish resolution for sure, and dirty water etc a big problem too which is why I put mine up high, of course the tow hitch is low and out of sight. It would be wouldn’t it. Laughing
This is the one I have:
https://www.amazon.co.uk/PARKVISION-Revers...&psc=1 WeWillWin🇬🇧🇺🇸
Post #1046933 26th Sep 2024 11:44pm
hoover
Thanks Chaps, some interesting solutions there, food for thought.
All I need now is for it to stop raining, but Im in North Wales, so......................yeah............... Rolling Eyes Freelander 2 Flora
Post #1046952 27th Sep 2024 8:45am
