Home > Technical > Tracking sorted, but still pulling to the left |
Shafski Member Since: 19 Jun 2023 Location: Chilterns Posts: 112 |
Mine used to do that, turns out the top mount bearing had failed. Shafski
_________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
21st Sep 2024 6:11am |
BaronDefenders Member Since: 28 Jun 2019 Location: London/Cotswolds Posts: 903 |
Another thought: possibly a binding brake calliper on one side? Charlie
1949 Series 1 80 (SOLD) 2002 Td5 90 (SOLD) 2008 Freelander 2 (SOLD) 1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored) 1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE) 2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK) 2012 Puma 110 Zermatt Silver (Overlanding Build) Instagram: @BaronDefenders |
21st Sep 2024 7:01am |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5792 |
Where is the top mount bearing on a Defender ???
What’s the steering box centred when it was tracked? Or have they just tracked the wheels to each other? |
21st Sep 2024 11:29am |
pjm-84 Member Since: 12 Apr 2021 Location: Hampshire Posts: 666 |
I had two vehicles do this for years. Both were related to the tyres. Stupidly cured one vehicle and put the same brand / tyre on the other..... and had the same problem.
21st Sep 2024 3:04pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20590 |
Different tread depth, tyre age, balance etc can do these kind of things. Play Stupid Games, Win Stupid Prizes.
Big Brother is Watching. 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
21st Sep 2024 5:45pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 793 |
Ideally on a ramp, stick a lever bar in between the axle and the radius arm and apply some pressure. Compare one side to the other. When the tracking was done did they check the steering wheel position relative to road wheel position and the condition of all the ball joints etc? Is it under load or braking it's most noticeable, or does it follow camber or poor road surfaces? -Check the panhard rod bushes -Check tyre pressures and wear condition all round -Check for wear in the swivel pins -Check for wear in the a frame bushes, trailing arms and a frame ball joint- the bushes on the a-frame in particular can give a weird passive rear-wheel steering and pulling feeling as they deteriorate. Hope some of this helps, it can be a pain to track down the cause on defenders as it's often cumulative things. Chris |
21st Sep 2024 5:57pm |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3345 |
All the above but also do you trust whoever did your wheel alignment? I only ask as I was having issues despite getting it done multiple times and it was only sorted when I took it to a motorsport and Defender specialist. It was a revelation and has gone from wayward to handling on rails. WARNING.
This post may contain sarcasm. |
21st Sep 2024 6:40pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2653 |
Might be worth removing the steering damper and cycling the travel to ensure that it is moving as it should.
Secondly, is your damper a version fitted with a spring, the yoke that holds it does have a habit of allowing the spring to rotate, come out of the yoke and push the steering to one side. Failing that you could try a tyre rotation. |
21st Sep 2024 9:10pm |
Top pin bearing! You can see my mind was elsewhere! Shafski _________________________________________ 2015 110 Montalcino Red Utility "Harriet" along with Puma on I.C.E |
22nd Sep 2024 7:07am |
phillips321 Member Since: 16 Dec 2021 Location: UK Posts: 103 |
How can I check this top swivel pin bearing? When hacked up and on axle stands the wheel/steering feels solid. |
11th Oct 2024 4:12pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 |
What Chris said and the bold bit. ? Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
11th Oct 2024 8:05pm |
Yes 100% more noticeable when accelerating or braking and on poor road surfaces: |
14th Oct 2024 7:44am |
Yes defo this. |
14th Oct 2024 7:45am |
