Home > For Sale & Wanted > [For Sale] Couple of bits
1x JVC KD-X230 Head Unit, sold used a couple of times was my spare, works well and was working when removed, is like new almost and has original box, wiring loom (din iso), fascia etc.
4x Kenwood KFC-S1093 10cm / 4” speakers, sold were working when removed, works well with the above.
Grilles painted semi gloss black, two grilles have slight modification to screw holes entry, but will fit rear Puma 10cm fittings and others of similar size. (This is the reason for the slight modification to the screw holes).
You will need screws. The rrrp on these new was £40 ea.
1x Morris K48 Grease tube.
The above is as a packaged lot or (£20 + post ea for speakers or HU)
£40 sold
1x sold Genuine LR A Pillar trims, like new condition, needs screws.
£10
1x sold Genuine LR jack foot for the pillar style jack.
1x sold ratchet handle for this jack
£10 lot, perhaps best to collect due to weight as postage would be almost the same price I expect.
I can courier if wanted.
1x sold Kenwood KCA-BT300
Bluetooth Unit. (Will only work with compatible Kenwood Head Units.
Unknown if working, believed to be when last removed, needs Mic input and suitable HU to host it.
See your Kenwood manual to see if it’s a compatible accessory if you have one.
£10
1x sold Genuine LR Aerial / Antenna, good condition, not bent, no damage when extended.
All parts inc for fitting.
£15
BACS for payments please.
Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1046106 18th Sep 2024 2:06pm
excossack
I am guessing that 1x Genuine LR Aerial / Antenna is FM only and not DAB/FM? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1046107 18th Sep 2024 2:17pm
As far as I’m aware you can use it for DAB, if you fit an inline DAB booster.
https://www.ebay.co.uk/itm/155080490489?_s...BM0sGZ38Bk
(The above link & supplier is not connected to me).
It definitely does cover AM&FM out of the box.
I’m pretty sure people on here use them as DAB with an inline DAB booster.
I don’t think the boosters cost much, just need a small fused power supply to them.
Post #1046119 18th Sep 2024 4:23pm
DSC-off
Hi, PM sent regarding the aerial.
I'll take it if it's still available, thanks. Thumbs Up
Post #1046145 18th Sep 2024 8:18pm
excossack
Go for it DSC-off. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1046146 18th Sep 2024 8:24pm
Antenna sold to DSC-Off. Thumbs Up thank you ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1046148 18th Sep 2024 8:30pm
Details of the HU:
https://www.crutchfield.com/S-CBS8ZuidC1Z/...-X230.html
Speakers:
https://www.kenwood-electronics.co.uk/car/...ew=details ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1046149 18th Sep 2024 8:35pm
Very Happy Revised prices on the HU & Speakers plus the Genuine A pillar trims.
Can post anywhere in mainland GB. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1046202 19th Sep 2024 12:51pm
L110CDL
Hi Steve
If the A pillar trims fit Millie, i will have them Whistle 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1046237 19th Sep 2024 8:03pm
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Bluetooth module
Hi Steve, I’m very interested in the Bluetooth module, if it’s still available, compatibility list says it will work with my set, could you post?
Mike Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #1046712 25th Sep 2024 4:49am
Both replied to - apologies for the delay. Thumbs Up
Regards the JVC HU and Speakers, happy to spit those if anyone wanted one or the other rather than just a bundle together. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1046826 25th Sep 2024 10:34pm
Update -
1x Wipac LED number plate light with original box, this is the one with superior SMD LED chips, nice white light, not blue.
Tested all working in good condition, also includes Genuine LR mounting plinth. Plinth could do with polishing or painting. Needs fixings I believe M5.
£15 posted.
2x Passenger grab handles in black, headlining handles, inc screws.
These can be fitted to the vertical small section of the headligning into the lowest edge of the roof, which is useful for passengers in the rear of a 90 HT or SW, or 110 HT or SW.
They can be used elsewhere if needed, or even off of a vehicle all together.
£10 posted.
4x Genuine LR Diff plugs, good condition, take off parts. 2x per axle are required.
£20 posted. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1047036 27th Sep 2024 9:30pm
L110CDL
L110CDL wrote:
Hi Steve
Many thanks Steve, got them today all good with the packing Thumbs Up 1996 Golf Blue 300Tdi 110 Pick up.
Keeper.
Clayton.
Post #1047336 30th Sep 2024 8:27pm
You’re welcome. Thumbs Up ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1047343 30th Sep 2024 8:46pm
Thread updated with pics. Very Happy ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1047767 5th Oct 2024 3:27pm
