Home > Td5 > Brake lights - or the lack of
excossack
Noticed last night I had no brake lights. I have side lights.
Coincidence since working on the dashboard or just bad timing.
First port of call is checking the fuse. (F13?)
The brake light switch, if I recall is mounted to the brake master.
After work, let the hunt commence! 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1046101 18th Sep 2024 1:20pm
BrickBox
Check the bulb holders are in good order. 2008 2.4 110 Utility Station Wagon XS.
Post #1046102 18th Sep 2024 1:37pm
excossack
The high level one is a normal bulb, the other ones are LED. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1046105 18th Sep 2024 1:42pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Brake light switch on top of brake pedal tower…. Pull it rebuild it or replace it.
Good luck 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #1046122 18th Sep 2024 5:29pm
excossack
All issues related to the brake switch. Corroded terminals and the switch playing up.
Ordered a new one.
Cheers all 1999 Defender TD5 110
Regards
John M0VAZ
Post #1046143 18th Sep 2024 8:13pm
4RF RDS
Glad it worked out and it’s an easy fix 👌🏻. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
Post #1046144 18th Sep 2024 8:17pm
excossack
Yep. Fingers crossed. 1999 Defender TD5 110
Regards
John M0VAZ
Post #1046147 18th Sep 2024 8:25pm
