Home > Td5 > engine management light / missfire
Page 2 of 2 <12
bob neville
Hi Amond
Did you get the problem sorted ??
Bob
Post #104609 4th Dec 2011 8:20pm
amondeggs
United Kingdom 1999 Defender 90 Td5 HT Woodcote Green
Right in a word no not yet, Rolling Eyes
Had to get recovered by low loader to get home today
the mechanic that came out thinks it may be the fuel pump Question
Will take to local landrover garage to be plugged in asap
Will let you know as soon as I do
thanks again to all who offered help Thumbs Up
Post #104647 4th Dec 2011 10:30pm
amondeggs
Right update for you all who have been following this or offered help.
Got car back tonight, turned out to be the ECU that had completely failed Shocked
Really annoyed at this as it had been remapped to give more performance.
I had the original ECU in the loft so that is now fitted and the car runs, not like it used to but it runs. The garage said that something had caused a spike and taken the ECU however they were not sure what.
Just before going off to Salisbury I fitted a wading plug in bell housing because of all the water we would cross. Tonight I removed it to see if water had got into the bell housing. I discovered that there was no water but some mud. Obviously there was water that has now drained / evaporated off. If I had the wading plug fitted how would water get in the bell housing Question I don't want this happen again.
Also need to get performance back so need to buy new ECU (NNN) TYPE) as the one I have fitted currently is the old type. Ideally would like one already remapped? Can anybody on here help me with that Question
Please let me know
Post #105131 6th Dec 2011 8:04pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
I'm not 100% certain on this, but I think Td5 injectors are coded to the ECU. What I mean by this is that their characteristics are all slightly different, so the after manufacture the injectors are bench-tested and given a 'code' which allows the ECU to compensate for variations in their performance.
So, if you install an ECU out of another vehicle, it will run but probably quite rough, and certainly not as well as it could.
Post #105175 6th Dec 2011 9:32pm
amondeggs
Does anybody know of any good ECU repairers in the West Midlands Question
figuring that it may be more cost effective to repair old ECU than buy new and then remap ?
thanks in advance Thumbs Up
Post #105197 6th Dec 2011 10:47pm
amondeggs
Right another update,
Over the weekend I refitted the ECU that appeared to have let me down. The one that the garage thought was at fault. Well it worked just fine Shocked
Took car back to garage where they did the diagnostics and they were just as surprised as me Exclamation
My problem now is what had got so wet that it caused this engine management light fault and upset the ECU so mush that the car would only run on tick over Question
I did play rather too much in some quite deep water just before this happened
I know it could be
1) the throttle pedal / faulty or just very wet Question
2) some have mentioned the crank sensor (apparently just a magnet) but told that if it had failed engine would not run Question
3) I have checked wastegate on turbo and this is fine Exclamation
4) No oil in harness / ecu plugs Exclamation
5) No water in fuel / air box Exclamation
does anybody else have any ideas what could have gotten too wet and caused this problem Question
Post #106460 12th Dec 2011 7:34pm
landy andy
Mate had exactly the same, we put new crank sensor on, and problem has never yet returned.
Andy
Post #106470 12th Dec 2011 7:50pm
amondeggs
Cheers Andy I will fit a new one as a matter of course, appreciate your help Thumbs Up
any other ideas Question
Post #106472 12th Dec 2011 7:55pm
ben2012
I've just had exactly the same problem so interesting to read what you have done, I too went through some deep water but back in November and ony just had the problem so not sure if the two are linked really?! My local Indy has got a second hand ecu to fit and reprogram Tuesday so will see what happens. With all this talk of crank sensors it's making me wonder now Confused
Post #111259 1st Jan 2012 3:18pm
amondeggs
Hi ben to be honest I have not had time to do anything yet. But for the sake of a few quid I will fit a new crank sensor when I get chance. The car runs fine now that it has dried out. My worry is what will happen if it gets wet again. I guess only time will tell Thumbs Up
Post #111354 1st Jan 2012 10:45pm
changill
United Kingdom 2003 Defender 90 Td5 HT Bonatti Grey
Did the ECU get wet? Have a look in the seat box and see if you have a "tide mark" above the ECU.
I had a friends disco2 that had a wet ECU. A day drying on the radiator cured the fault.....and never returned again (18+ Months).
Though there were about 15 Fault Codes in the ECU after the incident!
And yes that is me in the water!
Also had a similar fault with a friends TD5 90. His TPS (Throttle Pedal) got wet. Again a thorough drying (Heating on full heat on the feet in the cab) sorted it all.
Good Luck
Chan
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Only Alcohol Can Save me Now
Nanocom Available in the North West
Post #111700 3rd Jan 2012 12:18pm
ben2012
Just to update on my problem, all turned out oil has come down the loom and done in the ecu!! strange though as nothing at the engine end thinking it might of had a new injector loom at some point before I got the vehicle. Anyway all back up and runnning now so fingers crossed no more problems !!
Post #112261 4th Jan 2012 10:22pm
Page 2 of 2 <12
