![]() | Home > Puma (Tdci) > Sliding Rear Window - water ingress help request |
Puma_MOG Member Since: 08 Sep 2017 Location: Cheshire Posts: 184 ![]() ![]() ![]() |
I did a few more water tests and at first was convinced it was leaking from the top of the window frame but to be certain I pulled the interior window surround to have a closer look. Which by the way was a lot easier than I thought with the hardest bit being the large firs!
The leak in fact is coming from the body foam seal which has a large gap. After readying the many threads on the matter here, am I correct in saying Sikaflex 221 is to be used here? I assume I am to fill the gap from the inside as much as possible, with the hopes it comes through to the other side? I noticed they sell a pre-treatment for the 221. Is getting this advisable? As strange as it sounds, I find myself happy to find the fault as now it's down to just sorting it ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 199 ![]() ![]() |
That’s a very smart interior!
I used sikaflex 291 on the outside foam only and it worked well! I used masking tape and did whole way around. |
Thanks for the tip and compliment Jerry!
I've been reading for the past hour on here and it seems some are giving warnings against Sikaflex. Perhaps I am over thinking it... I want to avoid putting a full bead of sealant on the exterior and hoping I can fill that void from the side. |
I also used it to seal the bulkhead foam and around the windscreen blocks- It stopped all leaks and has been watertight and outside for 8 years. Only negative is it cracks / breaks down a bit after roughly 5years or so, so I just reapplied over the top! I did mask up beforehand to get really clean lines and went over with a wet finger! Good luck.
Ianh Member Since: 17 Sep 2018 Location: Essex Posts: 2163 ![]() ![]() |
Why not use a Butyl mastic seal, , such as Screenseal from wayside adhesives.
https://www.waysideadhesives.com/ It’s non setting so will never crack, water and uv proof, easy to apply, smooth, and to press into gaps. plus lasts 60+ years and will not cause corrosion. More details here https://www.ebay.co.uk/itm/220348415415 |
