Home > Puma (Tdci) > Motor cranks but won't start - does it have an immobilizer?
Page 2 of 2 <12
Siwynne
Presume since it was a starter replacement the battery terminals were removed and replaced in the correct order. +first. Try it. Relock the truck. Sometimes working in a garage vehicles sit permanently open. Close all doors and bonnet. Rearm the alarm using the locking fob. Try again.
My 2.2 will crank but not restart if I don’t follow these steps
Post #1045270 9th Sep 2024 5:55am
mrodey
Sweden 2009 Defender 110 Puma 2.4 CSW Scotia Grey
Siwynne, there is no FOB and the immobilizer is bypassed. How would the battery or immobilizer system interrupt fuel getting to the rail?[/quote]
Post #1045272 9th Sep 2024 6:22am
Martin
Site Admin
Are you getting a correct (low) coolant gauge position and a battery + oil warning light on the cluster when you key on?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #1045273 9th Sep 2024 6:30am
mrodey
Martin, coolant is pegged at the bottom and battery oil light is on if I remember right.
Post #1045552 11th Sep 2024 1:39pm
Siwynne wrote:
Presume since it was a starter replacement the battery terminals were removed and replaced in the correct order. +first. ...
The order in which the battery terminals are disconnected and reconnected cannot make the slightest difference (nothing on the vehicle can determine which order you've used). The only reason why good practice dictates disconnect earth first and reconnect earth last is to reduce the risk of shorting the battery by grounding the non-ground terminal with a tool.
Post #1045577 11th Sep 2024 4:50pm
mrodey
Car came back from another mechanic who confirmed immobilizer was set to off.
Could the VCV suddenly have complete failure and prevent fuel from getting to the rail? Trying to eliminate options here. Never had any limp mode, power loss, etc. before it suddenly stopped starting.
Post #1045618 12th Sep 2024 9:43am
mrodey
Well after a week at the mechanics with no progress I rolled my sleeves up and got busy. Long story but in the end... air in the fuel line caused air lock at the pump in the motor (2.4 so no pump in fuel tank). Thanks for all who contributed to this weird issue that shows no reason for happening.
Post #1045884 15th Sep 2024 6:35pm
Thumbs Up TheThunder Rolls🇬🇧🇺🇸
Post #1045886 15th Sep 2024 6:57pm
Page 2 of 2 <12
