Thanks, but I need to access the pipes to re-route to a new primary filter with a manual priming pump setup and then use the original (but at 2um) as a final filter.Puma 110" SW
15th Sep 2024 3:41pm
rustandoil
I considered cutting a hole in my floor, but couldn't bring myself to chop through the floor support
15th Sep 2024 7:56pm
ickle
on my Puma & I assume MK's truck, you cut close to the support but just behind it - it may be different for a TD5 ?
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
