Home > Technical > Cutting a hole in rear tub floor hole ok?
WindyJ
Any structural reason why a 10cm diameter hole could not be (carefully) cut into the rear floorplan above the fuel tank? I need to change the breather hose as it’s split at the tank end. Normally would need to drop the tank but looks like a right pia so I’m thinking of cutting a hole directly above it so I can access the clip holding it onto the fuel tank. Can’t see why I can’t do that but I’m no structural engineer.... but would turn a few hours job into minutes.
Post #745056 10th Dec 2018 9:50pm
ickle
I did mine about 6 years ago (110 sw) to fit a dip tube for the Eberspacher cab heater and its not fallen in half yet!
Not a huge clearance under so be careful how you or with what you cut with, I used a Monodex hand cutter then just silicone a flat piece of aluminium over when done.
With a torch, tape measure and a bit of patience, you start with a small hole and can get pretty accurate. IIRC a member on here did a write up on the same procedure on a 90, Danielle Gardel ?
Good luck
Keith
Post #745066 10th Dec 2018 10:26pm
TJH1985
I had the tank out to do mine, it’s a very quick job if you are firm with it from the get go Thumbs Up
Then again when the fuel pump failed, and again to fit the webasto pick up Rolling with laughter
I have changed the design on my tank cradle, so that it bolts on from the underside, rather than sitting on top and haveing to be forced out.
Post #745072 10th Dec 2018 10:53pm
JimC
United States 2007 Defender 130 300 Tdi HCPU Arles Blue
It’s not that bad to drop your tank a bit. Much better than cutting a permanent hole in your truck.
Post #745084 11th Dec 2018 12:17am
DAZ110
Post #745088 11th Dec 2018 12:37am
ChrisDefender
Not a big or too tricky job to drop the tank out. I had it done at a local a few months back and there were no real issues. Better I would have thought than cutting holes! They leak enough as it is!
Post #745147 11th Dec 2018 1:22pm
c18rch
United Kingdom 1988 Defender 110 200 Tdi HT Keswick Green
I've made the entire floor removable in mine (110 hard top) using chequer plate to replace the floor and rivnuts. I've had no issues. Makes maintnenace so much easier at the back end, you can stand up into the truck. 1988 110 200TDi Hard Top
Post #745149 11th Dec 2018 1:53pm
WindyJ
Thx for the suggestions/links people. I think if I had more time and didn’t have to work outside on a wet cold driveway then I’d set about dropping the tank and modifiying the hold points but for this one I’m leaning towards making the whole floorpan removable like c18rch - I can see how that could be very handy in the future!
Post #745155 11th Dec 2018 2:07pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
When I thought I had an issue with the fuel level reader/relay/pump (whatever) My mechanic suggested to cut a hole in the boot floor to make reaching it & changing it easier & quicker...
So I would assume it'd be fine! Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #745158 11th Dec 2018 2:18pm
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
I've cut a hole in mine. You can buy the right sized plate on Ebay to fit over the hole that is drilled to be riveted or screwed in place 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #745316 12th Dec 2018 5:49pm
Adam17
Thanks for the idea. Ill bear that in mind should I need to cut a hole... I think id like to at least try to get thye tank off, and replace any rusty/warn parts, and anti seize all the bolts. Regards
Adam
Loving The Duchess
Post #745669 14th Dec 2018 1:03pm
MK
2.4 110" floor cut out
Hello
I need to access the pick hole of fuel tank on my 110" and I do not feel like dropping it.
Has anyone done it and if possible to get the X-Y location on the floor?
Thanks in advance
 Puma 110" SW
Post #1045866 15th Sep 2024 3:26pm
ickle
Mines loaded to the gunnels at the moment, but if you look under the rear wheel arches with a torch you can see where the sender is in relation to the stiffening ribs and then find the rib from the top by looking for the spot weld (if I remember correctly)
Good luck
Keith
Post #1045871 15th Sep 2024 3:57pm
MK
That is a good idea. Thx Puma 110" SW
Post #1045872 15th Sep 2024 4:12pm
revd
Td5 110. Replaced my breather in situ: axle stands -remove osr wheel and mudfllap, 12” hacksaw blade with gorilla tape ‘handle’ to remove the pipe clip, genuine hose (marine hose is not flexible enough to weave through the chassis) new jubilee clip at tank end tightened with a long 1/4 drive extension.
Post #1045875 15th Sep 2024 4:33pm
