![]() | Home > General & Technical (L663) > Upgrading Speakers in 2023 Defender 110 |
Defendit.. Member Since: 09 Aug 2020 Location: 's-Hertogenbosch Posts: 436 ![]() ![]() |
Welcome to the forum,
1st. forget 4ohm speakers, half the volume with our amplifier in the Defender. You'll need 2ohm. This will reduce your search for speakers with over 90% and increase serious the price. No need for a crossover, active. You will need speaker rings or ( as I did with the rear speakers ) remove the driver from the original speaker. Than the connectors will stay the same. See my thread https://www.defender2.net/forum/topic83928.html ![]() Click image to enlarge ![]() Click image to enlarge No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 2951 ![]() ![]() |
Well, the O/P disappeared but l want to fit a subwoofer to my 2022 90 Commercial, which doesn't have one as standard.
l can get the subwoofer from a breaker, and can see where it fits, but how would l connect it to the amplifier? |
@lightning
I did activate the subwoofer with the IIDTool. The subwoofer adjustments appear in the pivi audio settings. Problem with this setting is that the woofers in the door not receive full bass anymore. So my 6 speaker systeem sounded a lot worse. Went back to No Subwoofer setting. Again, sound deadening and good speakers.. Really all You need. No Mud flaps for my 90.! ----------------------------------------- P300s MY21 Keswick Green on air, adv.+ offroad pack, DRL+fog, Dinamica Suedecloth + Ebony headliner/Cross Beam- Many Mods.. |
Thank you for the reply. l'll forget the subwoofer and just fit some better door speakers.
docbrock1974 Member Since: 09 Nov 2024 Location: Georgia Posts: 1 ![]() ![]() |
Can you tell me more about how you activated the subwoofer with the IIDTool? I can’t figure out which configuration to use to get it to turn on. Thanks!
EUCD 121 Subwoofer = change not fitted to fitted No Mud flaps for my 90.!
