![]() | Home > Puma (Tdci) > Key Fob Dead, central locking locked - Help |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20711 ![]() ![]() |
Vehicle battery voltage below expected voltage due to some kind of parasitic current drain.
Possibly. Hence why no fob sync. Another possibility is ground fault, creating similar circumstances as above. These things just happen out of the blue, and maybe due to ambient temps dropping a little recently at night. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
Paddington Member Since: 15 May 2020 Location: Oxford Posts: 43 ![]() ![]() |
Thanks for the response....would changing car battery solve the problem or charging the battery?
i'm lost when it comes to electrics. we're meant to be off on the NC500 around Scotland on Sunday for a week! thanks again, Neil |
Thanks Custom90,
Twas the original battery causing the problem! At the risk of being melodramatic, that's my holiday saved! Thanks again, Neil |
Glad to hear that all was well, I would recommend you try and find what caused it or ask someone to find it though for you as there is some parasitic drain, or the battery if it is old maybe past its best.
One of the other, just to be safe so it doesn’t happen again. Have a good holiday. ![]() ⛽️🛢️⚙️🧰💪 |
