![]() | Home > For Sale & Wanted > [Wanted] TD5 110 centre silencer |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 878 ![]() ![]() ![]() |
If it helps, I will buy the straight through centre silencer off you if it’s going cheap. I believe the TD5 and Puma 110 centre sections are the same? Is it the centre section from Maltings/terrafirma?
I would swap/exchange, but my standard centre section isn’t in great condition. I’m local to you. ![]() |
htb2 Member Since: 02 Nov 2018 Location: Carmarthenshire Posts: 537 ![]() ![]() |
Brickbox, We should be able to sort something out, my centre box was splitting down the seam, mind you it has done 260k. I only put straight thru on yesterday, will what it is like tomorrow.
Where abouts are you? |
Just outside of Swansea. 2008 2.4 110 Utility Station Wagon XS.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8166 ![]() ![]() ![]() |
I think I have one. Travelling to Abergavenny way from Taunton end of Oct. Message me tomorrow 07997 638635 I will check garage. Cheers
1NRO Member Since: 22 Feb 2015 Location: cumbria Posts: 72 ![]() ![]() |
If you have no luck with others I have one I’d selll, I’m in Carlisle if your passing.
rustandoil Member Since: 08 Sep 2012 Location: Cotswolds Posts: 784 ![]() ![]() ![]() |
I have one here from my 2005 110, removed ages ago but looks to be in good condition.
£20 which I will donate to Air Ambulance, collection Cheltenham |
