Home > Td5 > Which fuel filter housing suggestions please. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
Gore have stopped trading.
Pioneer is your next best bet. Instagram @defender_ventures Empire Tuning - Agent |
29th Aug 2024 8:36pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8113 |
I suggest a breakers and source one from an accident damaged puma. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
30th Aug 2024 6:37am |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1099 |
I saw the other day Turner is selling a replacement
https://www.turnerengineering.co.uk/produc...&_ss=r Did not look elsewhere, just came across it as I was shopping for something else. |
30th Aug 2024 6:43am |
why? Probably already gone porus and if it hasn't will rot away soon enough. Either an OEM replacement which should last you 10 years or get the pioneer that will likely outlast the life of the car. Instagram @defender_ventures Empire Tuning - Agent |
30th Aug 2024 8:20am |
Just giving options. Cheers
30th Aug 2024 9:41pm |
DC101 Member Since: 01 Jul 2012 Location: Pudsey, West Yorkshire Posts: 260 |
A belated thanks all for your valued replies.
Like the look of the pioneer offer, but they don’t do the pipe connectors so would have to look to source those independently, but no joy with that as yet. Gobsmacked that the part from Landrover was quoted me as £432. Cheers |
4th Sep 2024 12:07pm |
I was quoted similar a while back. Didn't want a copy so bought a genuine one from a scraper one front ended def. £40. Been fine since.
I do have a 2nd hand one here from m57 conversion. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Sep 2024 8:22pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
Puma filter housings are different to the Td5 as the puma ones are plastic.
I’ve fitted a few Pioneer ones and they are good quality and won’t corrode like the original. I fitted one to a 90 this week in fact Click image to enlarge Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
5th Sep 2024 5:40pm |
Also the unions screwed in it are brass and will come out no problem.
You can buy the valves in them separately VUB503950 Make sure it comes with the red duck bill non return valve WJN500110 Air bleed valve Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
5th Sep 2024 5:44pm |
