Home > Maintenance & Modifications > suspension spring isolators |
kinleyper Member Since: 05 Sep 2024 Location: USA Posts: 1 |
I’ve used Disco spring isolators before and found them really helpful for improving ride comfort. From what I remember, it's typically the D1 isolators for the rear and D2 for the front. Just to be sure, double-check with a parts supplier or forum, as things can vary. I also tried some NVH isolators from Mantaline on my previous setup and noticed a significant reduction in noise and vibration, which made the ride much smoother.
5th Sep 2024 2:30pm |
That's correct for a 90 but a 110 is slightly different as the rear springs are a larger diameter. See my post at the beginning of the thread. Darren
5th Sep 2024 3:22pm |
