Home > Puma (Tdci) > MT82 drain plug - should it have a crush washer?
Scrawf
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Tamar Blue
Hi guys
Just wondered if the drain and fill plugs for the MT82 gearbox on a Puma should have a crush washer or not? I swapped the oil today and neither of them did but I notice that there is a small drip developing on the drain plug Sad
I tried nipping it up a bit but it still seems to leak.
BTW the gear change is much better since the oil change!
Thanks
Scrawf
Post #551205 25th Jul 2016 9:28pm
Bluest
There is no washer I don't think. I used PTFE tape on the threads to ensure a good seal.
Post #551214 25th Jul 2016 9:55pm
ericvv
Post #551250 26th Jul 2016 5:19am
AlanH
Australia
I just use a drop or two of gasket sealant on them and the drain plug. They never leak so I'm happy with that.
AlanH.
Post #551280 26th Jul 2016 9:19am
Martin
Site Admin
No washer shown on the parts catalogue.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #551312 26th Jul 2016 11:35am
Scrawf
Many thanks. PTFE has stopped the drain plug leaking. Just have to find out where the other leak is coming from!
Scrawf
Post #551892 28th Jul 2016 2:15pm
HardCharger
Maybe replace it with a Diff Lock Drain?
Post #552050 29th Jul 2016 3:35am
macfrank
Germany 2015 Defender 110 Puma 2.2 SW Keswick Green
I've just had the oil changed and they used a copper washer.
I can now say that you still have to tighten the plug correctly to stop it from leaking Rolling Eyes
I tightned it to 35Nm for now (no leak so far), but the LR workshop manual says 50Nm.
Would that be ok or too much for the washer?
Post #1015663 19th Nov 2023 5:26pm
What are you all using for the threads with these plugs?
Options I’m considering are;
Hylomar blue universal, yellow, PTFE tape, loctite 222.
Probably not the 222 as that’s a light duty thread lock, not so much of a sealer. (Doubt it would play well with oils either, but good for general jobs).
Hylomar blue / yellow is very much the same thing almost.
Then there is PTFE tape.
I’m 50/50 between Hylomar blue and PTFE tape, probably leaning towards the latter.
I see BlueST already posted regards PTFE tape.
Anyone have any thoughts ? WeWillWin🇬🇧🇺🇸
Post #1044819 4th Sep 2024 8:31pm
Double post* WeWillWin🇬🇧🇺🇸
Post #1044820 4th Sep 2024 8:32pm
macfrank
I don't know what my workshop used other than the copper washer. On my motorcyles a washer alone was always sufficient Confused
Regarding the torque it seems 50Nm as stated in the LR workshop manual is wrong and it's actually 35Nm - same as the filler plug. That information is from an experienced mechanic I trust and Getrag's MT82 manual. What's your experience?
Post #1044828 4th Sep 2024 9:15pm
I think for the size 35NM seems about right for both fill and drain, I think 50 is too much for the drain, which is up nearer the diff plug torque which is 60NM, those plugs are much much larger in the diffs.
(Transfer box 30NM for both filler and drain).
There are some errors in the WSM for sure.
It’s strange that for a 2.4 puma the MT82 is stated as taking 2.4L Qty.
The 2.2 Puma takes 2.2L.
Despite the fact that both are the same transmission.
I believe the 2.4L figure is stated as dry fill and 2.2L service fill, however, the above is stated in the WSM.
Regards threads I tend to just go with the Hylomar that’s already on diff plugs, if they ever weep or any issues switch over to PTFE tape, both work without any problem at all WeWillWin🇬🇧🇺🇸
Post #1044845 4th Sep 2024 11:11pm
