Home > Puma (Tdci) > Can’t select 4th gear
Zed
Today I lost 4th gear but all the rest work fine. Presumably I need a new gearbox but wondered if anyone has had the same or knows what could have failed? WARNING.
Post #1044668 3rd Sep 2024 3:25pm
When you say "lost" do you mean that the gear can be selected but there is no drive, or do you mean that the gear cannot be selected?
Post #1044684 3rd Sep 2024 4:41pm
Zed
It can’t be selected. As you try to engage you can feel something rubbing but it won’t go in. I didn’t try to force it but did try to ease it in. WARNING.
Post #1044691 3rd Sep 2024 5:25pm
Could still be a clutch spring came out, depends where it went though usually affects all gears it can be variable in nature.
You’d need to have it looked at to see what is going on there first, then maybe needing more investigation beyond that. No Guts, No Glory.
Post #1044694 3rd Sep 2024 5:36pm
Zed
The clutch was changed a couple of months back but I will get it checked. WARNING.
Post #1044696 3rd Sep 2024 5:45pm
