Home > For Sale & Wanted > F/S OEM Defender 90 Door Hinges Stornoway Grey Finish. |
Swapped out my door hinges (front doors not Safari yet) for 316 s/s ones. OEM hinges in Stornoway Grey no paint bubbling. Ideal as a set for stripping, galvanising, powder coating or leaving exactly as they are. Bolts and fixings also in the package, no gaskets as I used them on the replacements. £40 plus p&p. If you go through life with your head in the sand....all people will see is an ar5e!!
3rd Dec 2011 6:36pm |
Mal
pictures please ... so to be clear 4 hinges (front door set) cheers steve |
4th Dec 2011 9:03am |
Steve,
Two are still fitted, about to swap them out today..... With two Defners of your very own I thought you'd know what a friggin' hinge looks like, you must be awash with hinges. Go on then I'll humour you.... Green bits go uppermost to prevent 'Dillons' fitting 'em wrong way up. Other side (driver's) are obviously a mirror image. Please don't request a picture of the bolts too! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
4th Dec 2011 10:37am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6105 |
Have you still got these Mal?
cheers Jamie |
11th Dec 2011 5:05pm |
I do! If you go through life with your head in the sand....all people will see is an ar5e!!
11th Dec 2011 7:17pm |
Looking at your profile picture MM there's two words....
Fat Chance!!!!! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
12th Dec 2011 7:42am |
spoil sport ... you know you want to
12th Dec 2011 8:27am |
