Home > 130 > 35's on a 130 - New project
Phib
1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Haviing had a few 110's and 90s I have been looking for something different for a new project and have found a grasmere green 130 double cab 2009.
Would like to do some mods to it to turn it from a farm truck to something slightly cooler !!
Would love to have some 37's on it but I belive that requires lots of mods so think I will go 35's which i belive will be 2" lift and some wider arches (probably 50mm) which I was going to fit anyway.
Wonder if anyone has any pictures of a 130 with 35's on it ?
Thanks
Phib
PS sorry in advance for all the daft questions I will now probably ask!!
Post #1044460 1st Sep 2024 10:25am
camelman
I had 35's on my 110, 2 inch lift and +50mm arches.
On my 130, I've left it on 235s, the ride and handling is much better...
Post #1044467 1st Sep 2024 11:56am
Phib
Thanks, that 110 looks great !!
Kind of aaware the ride will be comprimised
In the past I have had 90's with MTR's and they are not great, really could do with finding a ATR 35 .. if something exists
Phib
Post #1044471 1st Sep 2024 12:32pm
camelman
Bfg ATs are available in a 35 x 15. You'll need new.wheels anyway with a much deeper offset. I was running et-32.
I had those on before then MTs and the ride was still a bit yukky.
Post #1044483 1st Sep 2024 3:54pm
Chicken Drumstick
Phib
Do you mean Max Traction Radial as in the Goodyear MTR or are you meaning Mud Terrain (MT)?
Post #1044501 1st Sep 2024 7:19pm
Will.I.AM
United Kingdom 2005 Defender 130 Td5 HCPU Kaikoura Stone
These are all images with mine on 35's shoes. i do in fairness have 5/6 inch lift on it done by custom springs. I have the Glyn Lewis front mudflaps which rub slightly but I want to change them so that the mud flab is behind the bracket - hopefully this will eliminate the rub. I am also going to try a set of 37's on before i go for another set of rims to see if they work and how bad they rub etc but 35's do get tight - with 37's I would have thought you would definately want more than a 2 inch lift and if you can, get Adrenaline 4x4 to make you up cuistom length A frame and trailing arms for the rear to centralise the wheel in the arch with the lift and you would need a custom prop too.
 Defender 130 HCPU TD5
Series 2a 300tdi
L663 5.0 V8
Post #1044548 2nd Sep 2024 8:39am
Phib
Thanks for the reply, that looks great on 35's and what look like bowler wheels.
Certainly given me some inspiration.
I think with the level of work needed for 37's they wont be for me ... at this stage.
Many thanks
Phib
Post #1044552 2nd Sep 2024 10:05am
Will.I.AM
Thought i would share these on here after my previous post. Now sitting on 37's and i must say it does definateyl ride nicer and wierdly they were easier to balance! - according to the garage.
I am now awaiting custom trialing arms from adrenalin 4x4 and a custom extend fulcrum bracket and prop to get the rear axle back in the centre of the arch so that they don't rub on articulation.
Series 2a 300tdi
L663 5.0 V8
Post #1049528 23rd Oct 2024 12:49pm
Chicken Drumstick
Will.I.AM wrote:
5/6 inch lift
I suspect you can't have much suspension droop with that much lift. The rear wheel doesn't look like it is in the middle of the arch. Due to the arch radius of the rear arms. Longer arms or adjustable ones would help, but might be an issue on full compression as it'd then move the wheel backwards.
Post #1049530 23rd Oct 2024 12:52pm
Will.I.AM
Yes, that is my problem with the standard cranked trialing arms so have done a load of drawings and designed the arms extended in the crank so the mounts sit at factory angles) and extended fulcrum ball joint to make it work. They won't go right in the centre but will go back 50mm which means when I can drop my bump stops by 4 inches and have travel from this right down to as far as the trialing arms will let it hang out.
I get a lot of folk taking the Censored with the lift lol but did a friendly competition in the south of france where i blew a number of defenders and modded disco 1's out of the park with its articulation and managed to drive home via the Pyranees after Laughing Defender 130 HCPU TD5
Series 2a 300tdi
L663 5.0 V8
Post #1049532 23rd Oct 2024 12:59pm
