Home > Expedition & Overland > Broken shock in Spain |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 855 |
Absolutely fantastic news! This is what the Defender community is all about. 2008 2.4 110 Utility Station Wagon XS.
23rd Aug 2024 6:36pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20576 |
Good result, now no worries heading back. KEEP CALM AND Drill ON
23rd Aug 2024 6:50pm |
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 577 |
Great news,glad you got it sorted.
24th Aug 2024 12:07pm |
revd Member Since: 20 Apr 2024 Location: England Posts: 158 |
Glad you got fixed
The fracture on the OME looks like a duff weld. I know pin to pin is meant to be better but a well made eye fixing shouldn't fail even under extreme conditions, Defenders have been round the world on Konis etc using factory shock mounts. |
24th Aug 2024 12:54pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4227 |
When I'm home, I'll post some close ups of where it has failed. 2007 110 TDCi Station Wagon XS
24th Aug 2024 4:07pm |
Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 793 |
Its been a fairly well known issue with the OME shocks, initially it was blamed on people not cutting the cups off the axle mounts or using the wrong bushes. We have had one fail, I know of 2 others, same failure. Chris |
26th Aug 2024 9:27am |
I had it once due to fitting Polybushes, luckily no damage done and was only a mile from home.
I only use Genuine rubber bushes now onwards. KEEP CALM AND Drill ON 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
26th Aug 2024 1:56pm |
WestCountryPete Member Since: 30 Sep 2023 Location: Wiltshire Posts: 42 |
Great news that you got back up and running! Unfortunate that it broke in the first place but what luck to find someone at a random campsite with a spare! Hopefully the remainder of the trip was less eventful.
1st Sep 2024 7:12am |
If only, WestCountryPete! Got hammered in a biblical hail storm in central France which has ruined the roof and dented various other panels. 2007 110 TDCi Station Wagon XS
1st Sep 2024 9:39am |
Bit of a delay, but here are the pics of the break. One for the metalurgists...
Click image to enlarge Click image to enlarge 2007 110 TDCi Station Wagon XS |
9th Nov 2024 7:29pm |
Ultimately fatigue failure, the shiny bit is the repeated bending back and forth as the crack grows, the crystalline bit is the sudden failure of the reduced cross-section unable to bear the load. More analysis needed to determine what initialled the fatigue.
9th Nov 2024 8:12pm |
