![]() | Home > Puma (Tdci) > Handbrake drum rattle / rotation sound low revs |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
Check the condition of your prop shaft UJs.
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20626 ![]() ![]() |
Possibly the UJ nearest the rear diff nose, or another they aren’t that easy to check in situ though so check them thoroughly.
You can get mud or in-balance in the handbrake drum caused by ingress but isn’t that common as it usually comes out. The symptoms you mentioned does sound like a failed UJ as blackwolf suggests, especially as it improves at higher speed but more pronounced at lower speed. TheThunder Rolls🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
geds90 Member Since: 09 Jul 2024 Location: Cheshire Posts: 2 ![]() ![]() |
Thank you both - agree not that easy to check in situ, a garage will have it soon..
The only thing I couldn't figure is why the sound lessens to almost nothing when the handbrake is lifted just a little. I will provide feedback once it has been looked at. Thanks again |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2285 ![]() ![]() ![]() |
Propshafts UJs.
