Home > Puma (Tdci) > Safari Equip Single Arm Wheel Carrier fittting |
DiscoStu Member Since: 30 Jun 2007 Location: London/The far north Posts: 255 |
Morning all
Just purchased one of these, and am a little stuck on the installation. Picture is taken from their website. I have 2 of the plates marked with the tick (although mine are powder coated), and don’t have the plate marked with the ‘X’. Is this correct? If so, where does the second plate go, presuming the first sits on the outside of the cross-member? Click image to enlarge I’ve tried searching, but although there are several useful threads the pictures no longer exist. TIA, Stuart My Disco 'best bits' Defender 110 XS CSW 2013 |
21st Aug 2024 8:23am |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 286 |
The plates go either side of the Rear Crossmember, one inside the other outside, But I cannot remeber which one goes where.
Good bit of kit, but you need to add a grease nipple into the Pivot Bearing Tube to grease the Bearings, as water gets in. NormanD WE191 2015 110 XS Utility 2014 VW Caravelle 180 Executive |
21st Aug 2024 9:03am |
Ooops Double Post NormanD WE191
21st Aug 2024 9:37am |
Thank you
My 2nd plate won’t fit on the inside because it needs the additional cut-outs to fit I’ll have to send it back or modify it I guess. Seems a shame to cut it up when it’s powder coated. My Disco 'best bits' Defender 110 XS CSW 2013 |
21st Aug 2024 12:13pm |
