Home > Maintenance & Modifications > Alloy fuel tanks
Blue Blood
United Kingdom 1990 Defender 90 200 Tdi HT Bonatti Grey
Alloy fuel tanks
Hi all just wanted to pick everyone’s brains. I think my fuel tank has a slow leak. It is the tank that’s mounted under the driver seat for a 200tdi engine. I was just thinking why aren’t they made out of aluminium? I didn’t know if it were worth while getting a fabricator (specialising in fuel cells of course) to create one to sit in the same position with the same mounting tabs and everything with baffels to stop fuel sloshing around. I suppose my question is why aren’t these available already on the market??
Or am I missing something blatantly obvious? Any thoughts or help is much appreciated.
Regards Blue
Post #1043373 20th Aug 2024 8:53pm
TexasRover
Aluminium is more susceptible to cracking. Also more expensive and whats wrong with the original design, I believe you can still buy replacements no?
Post #1043396 21st Aug 2024 5:13am
Blue Blood
Yes replacements are still readily available but I just wanted to know if there was an option that could have even more longevity in it by material choice. I know some fabricators produce stainless steelvv no tanks too but mostly for marine based applications
Post #1043400 21st Aug 2024 6:27am
Mo Murphy
They used to be available in other materials. I bought a stainless underseat tank for my old 90 about 20 years ago.
50 Shades of Pennine Grey
Post #1043432 21st Aug 2024 9:07am
Zed
Give Allisport a call. WARNING.
Post #1043433 21st Aug 2024 9:07am
Blue Blood
Mo
I had seen some fabricators offering stainless but the prices are eye watering!!
Post #1043439 21st Aug 2024 9:52am
Blue Blood
Good shout I may hit them up to scratch their brains and see what they would suggest.
Post #1043440 21st Aug 2024 9:52am
Mo Murphy
Blue Blood wrote:
Mo
One time purchase though ! Fit and forget. I'm not sure I'd want an aluminium tank given its exposed position to road muck and salt and the fact that it'll be bolted to a steel chassis no matter how well you'd try to isolate it.
The most cost effective solution is to change to a TD5 / Puma plastic rear tank with a rear filler from YRM. That'll last forever and you'll get a 20l capacity boost to boot.
Post #1043454 21st Aug 2024 12:39pm
Anything of interest here:
https://devon4x4.com/catalogsearch/result/...e_make=315
? $W33T $0U7H3RN $UG4R
Post #1043458 21st Aug 2024 12:45pm
