![]() | Home > Off Topic > My Hummer H1 build |
Jerry Member Since: 13 Nov 2015 Location: Cardiff Posts: 199 ![]() ![]() |
Looks great - thanks for posting - always liked those beasts
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Do you know what current the Alternator puts out? Is there multiple Alt upgrades?
Guessing places like Mechman do maybe? I’d say it would be cool if you could fit an Inverter in so you could have mains 110v 2pin in such a big interior. I think quite a few people would be interested to see what kind of towing set up hitches etc y’all have. As we have different towing set ups in GB, as well as heavily limiting licensing on towing weights. ![]() Most common is 50mm tow ball and hitch for light and domestic towing, but there is NATO hitches. And then beyond 3.5tonne more heavy duty options and commercial plus more. You don’t tend to see 5th wheel set ups often, but there are some as have been seen on here with PU’s. Has anyone got any of the ahem new ones and put a proper motor in? Guessing with the serious price tag, it’s a really big money deal. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
H1Tad Member Since: 20 Jul 2024 Location: Maine Posts: 149 ![]() ![]() |
Thank you! Other than my fur-babies, its my pride and joy.
Factory came with a 140A alternator (CS144). I've got a Powermaster built 200A Alternator. The biggest CS144 alternator I've seen available is... 800A which is nuts unless you're driving something like an electric A/C Compressor or Electric power steering gear.
I've got a dinky little 400W inverter for when I need 110V. Which is not often. My camping trailer has a standalone battery bank with a 1100W inverter on it. The interior (which I just now realize I didn't picture) isn't very big. At all. The aforementioned driveline tunnel takes up a huge amount of space inside.
The setup with my M1102 camping trailer is a standard 20,000lbs (IIRC) pintle hitch/lunette ring setup. I've also fabricated a rotating NATO pintle hitch (pictured) for offroad use only. The H1 is rated to tow 7500lbs which isn't a lot - but the vehicle itself has a curb weight of about 7800lbs with a 10,300lbs GVWR. I've upgraded all of the components on the chassis (half shafts, brakes, drive shafts) to get it up to a 12,000lbs GVWR so I have about 3500lbs of payload in the truck alone.
Not that I'm aware of but I wouldn't put it past someone to try. I find them very, very ugly. It is quite common for H1 owners to swap out their old detroit 6.5TD's for Duramax engines which can be tuned up to about 1000hp. Personally my 350ish and 750lbs/ft of torque is plenty peppy for me. ![]() Click image to enlarge ![]() Click image to enlarge 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package 2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
LR did quite a good job for us with the Puma Defenders, 150A Alternator from the factory.
![]() There are a lot of vehicles that have a very low output though, so not great for audio installs. WeWillWin🇬🇧🇺🇸 ⛽️🛢️⚙️🧰💪 |
mini Anaconda Member Since: 23 Aug 2016 Location: Thames Valley Posts: 811 ![]() ![]() |
That's a beast
The original alternator was 128A. The 140A was introduced for the Monsoon 8-speaker/subwoofer setup.
Thank you! 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package 2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
Does it have 2 fuel fillers? Are they for different purposes?
Ianb Member Since: 25 Oct 2023 Location: Devon Posts: 417 ![]() ![]() ![]() |
Hey H1Tad,
Thanks very much for sharing this! I think there is a definite attraction to the H1 with it's agricultural "ugly" looks (in a complementary way that I love my ugly Defender!). That engine size though *yikes!* wouldn't be picking up my mileage in the UK with that. Well, I wouldn't ![]() Youtube - https://www.youtube.com/@YetitheDefender Instagram - https://www.instagram.com/yetithedefender/ |
Yes. Two fuel fillers for two fuel tanks. Main tank is 25 US Gallons, and the Aux tank is 17 gallons. There's a switch on the dashboard that I can change between the two one the fly.... even while doing highway speeds.
Of course the fuel selection valve, which is a Ford OEM part, is one of the pain points on the platform which frequently breaks. Knock on wood, mine hasn't yet. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package 2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
By switching to the marine injectors, I gained 3 MPG on the highway. Over here, 13MPG is actually not bad for a full size, heavy duty truck. I don't drive a whole lot of miles. I work from home so this thing takes me to get lunch a couple times a week and then go to the gym. On the weekends I use it to run errands around town or take it to the trails. Since it has a rather large fuel capacity, I only fill it up about once every 3 weeks or so. It does require a lubricant be added to the fuel since they forced the Ultra Low Sulfur Diesel over here a while back. Sulfur is the lubricant for the injection pump - and without it our IP's can wear themselves out fairly quickly. Found the P400 longblock thats in my truck. You can see the P400 stamped on the front of the block. We're not quite sure of the exact numbers, but we think they only made about 275 of these P400's - and I, through sheer luck, have ended up with two of them. ![]() Click image to enlarge 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package 2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
Some pics of the cargo area in the back. I just realized I don't have any good pics of the interior where its not all pulled apart while I work on it. So I'll present to you the joy of #doghouselife. Having to remove half of the dashboard in order to get to the back of the engine is so much fun. Especially since they decided to try and pack 15lbs of sh*t in a 5lbs bag back there.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package 2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
Lol I never let them go empty. As soon as I get the low indicator on the main tank I switch over to the aux and hit up the pump when I can. I typically top off for about $100 per fill-up lately. Didn't used to be that terrible but we are apparently sending a lot of diesel over to Europe while there's a certain geopolitical conflict ongoing.
Diesel used to be cheaper than "petrol" over here but now it's more expensive. When I got my first H1 I could escape the pump for about $60. As far as local diesel prices... it's right at about $4.29 a gallon right now. Cheaper in other states. I was just gown in Georgia for a family event and it was around a dollar cheaper down thete. 2022 Defender 110 SE P400 Tasman Blue Expedition and Cold weather package 2003 Hummer H1 P400 Firehouse Red 2008 Toyota FJ Cruiser |
Holy smokes! Visually it looks very compact. I wonder if it's deceptive. If I recall correctly they are very big/wide vehicles? So looking at the intrusions into the cab makes it seem quite cosy in there!
You should come over here for a trip and bring it for us to have a good ol' snoop around ![]() So you're running at about £0.87 per litre (UK litre) - (if my maths isn't failing me - also using Custom90s maths too!) Not quite half price compared to us, but probably one or two political bloopers one way or another to get there ![]() Youtube - https://www.youtube.com/@YetitheDefender Instagram - https://www.instagram.com/yetithedefender/ |
