Home > Expedition & Overland > Side storage lockers |
gcc130 Member Since: 05 Jun 2015 Location: Wiltshire Posts: 744 |
Fat cat are also side opening.
2nd Mar 2022 7:39pm |
Nakatanenga do this one.
Click image to enlarge |
2nd Mar 2022 8:02pm |
Thanks for that Timcat, I was looking at those joints and thinking I would seal them before fitting👍
6th Mar 2022 10:37am |
the shepherd Member Since: 27 Sep 2016 Location: surrey Posts: 18 |
I have FCX side lockers fitted - two on n/s one on o/s. They are made from light steel and have been on the defender for about 5 years.
After trying to open them today when they have been closed for several months, they were difficult to open and I had to use a lever to open them as the door hinges have corroded from road salt and the rust has expanded bending the hinges out of alignment. So trying to close them I had to hammer the hinges to try and realign them which has worked to a degree although a temporary solution. Looking at alternatives, the stainless steels ones available are smaller than mine so are no good plus very expensive. Has anyone had this problem - if so did you drill the rivets out of the hinge and clean and repaint or what? Cheers |
10th Apr 2022 2:50pm |
west4x4 Member Since: 23 Jan 2010 Location: Rutland Posts: 140 |
Just get the doors painted to match
27th Apr 2022 8:09pm |
foxhound Member Since: 02 Mar 2013 Location: United Kingdom Posts: 363 |
safari equip make side lockers for 110s -- military style for hard tops under bench wheel arch and for station wagos a rear quarter locker in the wheel arch dead space. i have one. 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
16th Aug 2024 4:11pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 740 |
Would you guys happen to know if these would work with Gwyn Lewis rear mud flap kits? No Better Friend, No Worse Enemy
19th Aug 2024 7:03am |
best ask safari equip -- it would be good to know as i'm looking at those gwyn lewis mudflaps and mudguards 110 Defender 300tdi & Penman trailer with ally exped top and roof tent
19th Aug 2024 1:52pm |
