Home > For Sale & Wanted > [For Sale] Brand new Defender slickshift for LT77 & R380
edo
Unused, and never got round to fitting.
Defender slickshift
A new innovative design exclusive to Syncro Gearboxes, the Land Rover Defender LT77/R380 Slickshift improves gear change by reducing sloppiness and minimising travel, as well as neatening shifts giving smoother gear changes.
The Syncro Gearboxes Slickshift is easy to fit and allows you to use your original gear stick. Within thirty minutes you can have a more modern feeling Defender, with gear selections similar to newer vehicles.
The Slickshift from Syncro Gearboxes is a direct replacement for the existing pivot pin. Included in the kit is the custom pivot pin and spacer plates as well as 4 new BZP 8mm bolts. Also included in the kit is a new nylon cup to replace your old worn out one.
For Defender LT77 & R380 ONLY (inc TD5 Defender) You’ll only need a pair of circlip pliers, a screw driver, 17mm, 13mm, and 10mm spanners for fitting. Can be fitted in situ’ within 30 mins. 2 spanner difficulty rating.
These are £100. I'll take £80 to inlcude UK Mainland shipping.
Compatibility:
Defender 110, Defender 110-2.5L D / TD-1983-1989, Defender 110-200 Tdi-1990-1994, Defender 110-300 Tdi-1995-1998, Defender 110-TD5-1999-2006, Defender 110-3,5L V8 Carb-1983-1992, Defender 110-3,5L V8 EFI, Defender 130, Defender 130-2.5L D / TD-1983-1989, Defender 130-200 Tdi-1990-1994, Defender 130-300 Tdi-1995-1998, Defender 130-TD5-1999-2006, Defender 130-3,5L V8 Carb-1985-1992, Defender 130-3,5L V8 EFI, Defender 90, Defender 90- 2.5L D / TD-1983-1989, Defender 90-200 Tdi-1990-1994, Defender 90-300 Tdi-1995-1998, Defender 90-TD5-1999-2006, Defender 90-3,5L V8 EFI, Defender 90-3.5L V8 Carb-1983-1992
Post #1042753 14th Aug 2024 2:01pm
Biscuits
United Kingdom 2001 Defender 90 Td5 CSW Epsom Green
Yes please Smile 2001 90 TD5 Soft Top - Epsom Green
2024 90 D300 HSE X-Dyn HT - Santorini Black
Post #1042766 14th Aug 2024 5:11pm
edo
First dibs, please PM me contact deetails and banks details and will post tomorow for you.
Ed
Post #1042783 14th Aug 2024 8:27pm
Bren_bruce_20
United Kingdom 1997 Defender 90 300 Tdi CSW Santorini Black
I’ll take this if the first sale is unsuccessful. Cheers
Post #1042787 14th Aug 2024 10:09pm
edo
SOLD and paid for by Biscuits. Thanks chaps.
Post #1042808 15th Aug 2024 9:25am
