Home > Maintenance & Modifications > LOF Brakes Powerspec Upgrade - User feedback please
Page 2 of 3 <123>
mark1200
England 2004 Defender 90 Td5 HT Caledonian Blue
Bluest, took the new pads out and put sandpaper in between the pads rubbed together to take off some material and thought i cleaned them up, no difference.
put the old pads back in the new calipers , no difference lol. i hear what you say about trying new pads .
i am almost 100% sure there in no air in the system as every time i have pressure bleed them there in no air coming out.
the frustrating thing is the old brakes were very good but the new ones have no stopping power at normal road speed, in a car park at say 10 mph there very good ??????
Post #1042328 9th Aug 2024 2:35pm
Grenadier
Hi Mark, similar situation. Did you fit it yourself? If so (or if not, do you know) did you fit the power assist thingy in the pedal box? Mine definitely doesn't look as if it has been opened.
Does anyone else know if the LOF power assist thingy is for all braking systems or just ABS?
PS. Still haven't found the time to check bleed the system. Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #1042718 14th Aug 2024 7:31am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
The LOF servo is for all systems without ABS. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1042719 14th Aug 2024 8:00am
mark1200
i fitted everything myself and am very confident in doing so. i expected the brakes to need bedding in but after 600 miles and no real improvment thats why i though the pads might be contaminated hence the changing them to eliminate any possible causes.
But to hear others are having the same issue ?????
As i cant pinpoint what is wrong i might strip all the brakes off and start again as i cant see why the brakes are so poor, i have a hard time beliving that LOF kit is at fault.
Post #1042756 14th Aug 2024 2:25pm
landy andy
I’ve bled my brakes probably 30 times. Litres and litres af fluid through mine multiple times. Power bled, primed via nanocom. Pressure bled, old fashioned foot bled, and reverse bled. Pulled off master cylinder, and adjusted. Swapped to braided hoses, have swapped ALL wheel bearings to new. Swapped to new rear brake callipers, but old were working. I’ve now got a slight improvement by fitting the LOF fast road pads instead of their basic pads, and a slightly better pedal after adjusting master cylinder.
But still not brakes I’m happy with.
Post #1042859 15th Aug 2024 8:12pm
a13x
Any update to these issues? Thinking about ordering a full set of calipers, discs and pads.
Post #1048963 17th Oct 2024 10:09am
mark1200
i got round to swapping the Lof brake pads to Ebc green stuff and there was an vast improvement as there is immediate grab of the brakes, caught be by suprise at first lol.
i have only done a few miles at gentle braking as i have to bed the pads in. but it all points to the Lof pads not being very good at all which is a shame
Post #1049069 18th Oct 2024 3:06pm
landy andy
Interesting. I’ve recently swapped across to the higher performance LOF pads, and also notice an improvement. Not a night and day change but an improvement. Maybe I will try something else.
Certainly interesting.
Thanks for info Thumbs Up
Post #1049079 18th Oct 2024 4:30pm
mark1200
final update, Ebc green stuff pads bedded in and i can now lock up all 4 brakes in the dry with out having to really stamp on the pedal so i now have nice powerful brakes and lots of feedback.
So the Lof pads i had were the cause of my problems.
Post #1050202 29th Oct 2024 3:30pm
landy andy
Interesting. Thanks for taking the time and letting us know.
As said above I’ve swapped to the LOF Performance ones, and got a small improvement.
Which LOF pads were you running before swapping to EBC?
What is the cost like with EBC
Post #1050204 29th Oct 2024 3:36pm
mark1200
I had the power spec discs and pads, dimpled and groved discs which are ok, the Ebc green stuff pads were £110 for front and rear. i understand that there a softer pad but i only do about 3000 miles a year so they should last me a while lol
Having strong brakes makes driving so much better .
Post #1050207 29th Oct 2024 3:58pm
landy andy
Think I may have to swap mine across to EBC as you were also “power spec” stuff.
I’m running the power spec discs, pads, and ss callipers all round.
Post #1050212 29th Oct 2024 4:58pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Right guys. Not been in on this thread from the start but......
Standard Defender brakes are pretty awesome without fooking around on 'upgrades' when they are working correctly. I'm running 33" tyres so pushing brakes pretty hard.
I have an early 300tdi with discs all-round. Twice in 10yrs I have found the brakes lacking. First time was due to a cracked servo losing vacuum. 2nd time just recently was due to brake pulling and found a leaking caliper had ruined brake pads on one side with fluid contamination. Solved with Britpart S/S pistons and genuine seals caliper rebuild,
Always run Mintex or Delco standard pads.
Just for context, my standard tune 300tdi runs like a dream, often easily hits 85mph (like every week when commuting) and handles/brakes predictably with OEM rubber bushes etc. You really don't need to do much more, Landrover got it right first time so if you are having to fit 'upgraded' parts to achieve safe braking/handling there is clearly something else wrong and you should look at fixing that first!
Post #1050235 29th Oct 2024 11:11pm
jst
I agree with all above, although will add heavy vehicles, those towing alot and performance upgrades do add the requirement.
Std brakes are more than capable of locking up 33s in my experience. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1050239 29th Oct 2024 11:58pm
Agree with JST above, I think the standard brakes are good to be honest.
If you do make changes though you’ll have to think about the long term effects of that, such as pad performance when cold or hot, grooved discs, if abrasive conditions are considered where they’ll increase pad wear or if drilled rotors a build up mud in them.
Things like that, regardless of brakes, tyres matter a lot too as they will lock up.
Post #1050270 30th Oct 2024 1:51pm
Page 2 of 3 <123>
