Home > Puma (Tdci) > Brake vacuum pump
spudfan
Ireland
Brake vacuum pump
Had an "oily" smell while driving the2008 2.4 Puma yesterday. Pulled the bonnet today and the tell tale signs of a failing brake vacuum pump were there to see.
It was changed before in March 2013 at 78,650 kms.
The current reading is 214,040 kms. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #1042400 10th Aug 2024 12:19pm
Probably simply the gasket needs changing, or is it from somewhere else the source of the leak?
The coupling doesn’t even need to come off, just unbolt, replace gasket after cleaning mating surfaces lightly and re-torque to WSM settings for the fixings and that’s it. NEVER SURRENDER! ⛽️🛢️👨‍🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
Post #1042405 10th Aug 2024 1:13pm
spudfan
Ireland
Kind of hard to tell but there is a lot of oil on the pomp bolts and the interior was well sprayed. Hard to tell if it is just the gasket. It is not a big job. Won't be driving it until the repairs are done...less mess to clean up! Even managed to coat the back of the passenger door mirror! 1982 88" 2.25 diesel
Post #1042407 10th Aug 2024 1:32pm
spudfan
Ireland
Update.
Left in the Puma 2.4 to get the vacuum pump replaced, also an oil/filter change as it was due. As the annual road worthiness test is due soon (your MOT) I asked him to check for anything that might need done. There were a number of things that needed seeing to, namely.
Front brake discs and pads were getting low so they were changed.
Swivel ball driver's side was pitted so that was changed.
There was an oil seep so the hub seal was changed.
A bearing was changed.
I intend to get the rear cross member replaced on the Puma next year.
While the Puma was in I was driving the 1982 2.25 series 111 diesel. Monday I was out and the fan belt snapped. Got home. Funny thing is that the fan belt was changed about 3,000 miles ago so there could be an alignment issue to cause it to go so soon.
Collected the Puma and left the series 111 in to the mechanic at .....6.30am this morning!
No bill yet as he has not made it out yet. 1982 88" 2.25 diesel
Post #1046764 25th Sep 2024 1:57pm
