![]() | Home > In Car Electronics (L663) > Strange Pivi Pro glitch? |
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1442 ![]() ![]() ![]() |
When you add your PIN is there not a box to tick to remember the code? Cheers Ian -------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1126 ![]() ![]() |
This got me the other day. There is a box, but if you don’t tick it at the time you set a new code, you can’t retrospectively tell it to remember it!
Solution is to go through the forgotten code process and tick it. Obviously reset with your normal code. It’s a computer at the end of the day, so will probably still be full of bugs after only 4 years of development. 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
