Home > Tdi > Missing screw - engine bottom |
ynsark Member Since: 06 Aug 2024 Location: Brno Posts: 2 |
Hello,
my Defender 1997 TDI300 110 from UK is missing screw at the bottom of the engine. I am unable to find it in catalog part. I presume its hole to check oil level but its not Oil Sump Bolt screw. Can anybody help me identify part number? Click image to enlarge Thank you a lot. Jan |
6th Aug 2024 1:24pm |
Thank you a lot. Good day.
6th Aug 2024 2:30pm |
jfh Member Since: 08 Jan 2014 Location: West Coast Posts: 357 |
It's a good idea to once in a while look into this hole and look for black fibres.
This will give you a indication if the timing belt is chafing itself to destruction. Only install plug when you are going to be wading. |
9th Aug 2024 10:41am |
