Home > Puma (Tdci) > Engine cut off when idling & strange power issues |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20201 |
Most likely VCV replacement needed (not very expensive)
Possibly Turbo EA getting stuck, possibly by sticking turbo vanes, lube on the pivots with 3 in 1 light oil. Do you happen to know how old the VCV is? When was the fuel filter last changed? NEVER SURRENDER! ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧 |
4th Aug 2024 1:25pm |
jim4244 Member Since: 13 Apr 2014 Location: Bedfordshire Posts: 754 |
Hi
Basically what Custom90 said. Replace the SCV/VCV with a new genuine Denso one. An easy enough job, if not a little fiddly but you can do it in an hour or so if you take the time to remove a few bits to make access easier. A genuine Denso replacement can be purchased for around £60-£70 off the internet. Jim |
4th Aug 2024 1:32pm |
Have a read:
https://www.defender2.net/forum/topic92524.html Jim |
4th Aug 2024 1:36pm |
