Home > Puma (Tdci) > 2.4 Tdci Puma with 231,000kms - started using Engine oil
Page 2 of 2 <12
RobM
Australia 1996 Defender 110 300 Tdi SW Alaska White
custom90 wrote:
I would tend to lean towards Turbo, if it’s very high mileage it probably is worth changing it anyway and will drive better anyway.
I’ve had a few people/mechanics suggest this..
I just wonder about doing a compression and leak down test to determine if it’s rings or not… Cheers.....
Rob
1995 Defender Tdi 110Wgn
1996 LR Discovery Tdi300 (A)
2009 Defender PUMA 110Wgn
My TRPS: Rob's WikiLoc Trips
Post #1041625 2nd Aug 2024 7:38am
MK
I have done a few compression tests on 2.4 and 2.2 Defenders but always with a cold engine. I am not sure if it is a valid test though. Puma 110" SW
Post #1041672 2nd Aug 2024 1:17pm
How much oily gunk is in the pipework between turbo and intercooler?
Post #1041674 2nd Aug 2024 1:32pm
RobM
I'm yet to remove but I assume it will be oily?
The section from where the breather hose intake is to the Turbo looks ok for its age. Its not clean but not clogged up either
I want to gain easier access to remove the IC so I was wondering if anyone can tell me if there are captive nuts on inside of the guard holding these bolts in place?
(see attached photo)
 Cheers.....
Rob
Post #1041724 2nd Aug 2024 10:16pm
MK
My 2007 has them. Puma 110" SW
Post #1041726 2nd Aug 2024 10:24pm
RobM
Do u know if they are a captive nut as in if u remove the bolt that the nut doesn’t drop down into the inner guard? Cheers.....
Rob
Post #1041731 3rd Aug 2024 2:17am
Dinnu
Captive nuts 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1041733 3rd Aug 2024 5:12am
I seem to remember that they are captive, go easy undoing them because you never know.
I think they are weld nuts behind there so fairly secure from spinning though, you shouldn’t have any issues. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1041739 3rd Aug 2024 8:07am
HardCharger
My 2011 D110 was consuming oil before as well and it was definitely the turbo. Don't get me wrong, it still drove great, it just needed quite a bit of top off with the engine oil and the turbo whine was louder than usual.
After the turbo was replaced, drove much better, more quiet, and didn't need top offs anymore with the engine oil.
While you're at it, have the intercooler cleaned out. Mine had A LOT of oil in it when we did this. Clean out the turbo hoses as well.
I hope this helps. Thumbs Up
Post #1041894 5th Aug 2024 4:12am
The MAP sensor often gets caked as well, that doesn’t help. Thumbs Up
The fixing for that is 3NM if anyone should want to do that and brake cleaner spray or MAF cleaner will do that, don’t touch or disturb the element.
Again, something rarely done with a service just left until failiure. ⭐️⭐️God Bless the USA 🇬🇧🇺🇸 ⭐️⭐️
Post #1041913 5th Aug 2024 8:14am
MK
I would rather use contact cleaner or isopropyl alcohol. Puma 110" SW
Post #1041935 5th Aug 2024 11:40am
Page 2 of 2 <12
