Home > Maintenance & Modifications > Diesel Heater Supply
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
Hey Folks,
I'm starting to amass the gear to install my diesel heater and see that there's potentially two ways to pick up the fuel from the tank.
There's a nice (but expensive) insert that fits into the filler neck and has an internal standpipe.
Then there's the plastic T-piece doo-dah (cheap as chips) that fits in the return line to the tank - I think.
What's the pros and cons between the two..?? Ones more than ten times the cost of the other and they both look relatively easy to install - or are they..?? πŸ˜„
Cheers, Dave 2002 Land Rover 110 Td5 Utility
1990 Suzuki GSXR 1100L
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #1041688 2nd Aug 2024 5:54pm
MarkBrown
Wales 1983 Defender 110 Other HT Auto Keswick Green
On my 110 I used a plastic T-piece cut into the main line as close to the pump as possible, fed through an in - line filter. I purchased a 2m length of alloy intake hose and ran it up to a better air intake under the bonnet, this all works fine, it even has a remote control. It takes around 15 minutes to heat up the space nicely on a cold day and can be used in tandem with the main heater if required.
On my sprinter van I drilled through one of the spare fuel line fittings in the fuel pump on top of the tank and ran it through a very long fuel pipe to the back of the van, where the unit it fitted. All parts used were in the kit, which again works fine. The pump is in the top of the tank, so the tank has to be removed.
I don’t know how easy it would be to fit the β€˜T’ into a plastic fuel line though, mines rubber.
I also tried a couple of brass fittings, thinking they would be more durable, but couldn’t get them to seal, this was probably just the one I picked.
Post #1041693 2nd Aug 2024 6:53pm
andy63
Not that you are likely to but for anyone that has the tank out and wants to plan for a diesel htr the pump sender unit has an existing dip tube that you can tap into by
cutting the sealed top off and fitting your tubeπŸ‘
Post #1041709 2nd Aug 2024 9:05pm
jst
I went for the option shown above into the tank through spare fitting above pump. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1041734 3rd Aug 2024 7:07am
Evil Elsie
Superb info/advice - thank you all..πŸ‘πŸ‘
The unused spur on the fuel tank sender would be the preferred/neatest option. I think a lot of folk have access panels cut into their tub floor to access the Sender - sadly not me though..πŸ™„
I'll most likely go for the T-piece in the fuel line - 'cos it's cheaper..!!
As a follow up question;
Would you mind telling me where you mounted the Pump..?? I'm going to fit my heater under the Cubby box so there'll be plenty of chassis rail to go for but I don't want to drill/tap the chassis to mount the pump... 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1041749 3rd Aug 2024 10:24am
Mo Murphy
There is no chassis under the cubby box, just transfer box under the seat box cover. Most people mounting their heater in this position use a dedicated box like those sold by Mud -
https://www.mudstuff.co.uk/products/mud-he...cUxpXAFOIp
Some people cable tie the pump in place or find an unused insert.
HTH
50 Shades of Pennine Grey
Post #1041781 3rd Aug 2024 7:50pm
jst
I fitted an insert to existing hole and bolted pump to that.
I.dont have an access panel just dropped tank to fit pickup. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1041791 3rd Aug 2024 9:56pm
Evil Elsie
Thanks Mo and JST,
I've just checked the installation guide and the pump is to be no more than 300mm from the fuel line T-piece, so that will limit my options....
That's a good shout on using an existing hole. Hopefully there's one in the perfect place... 😜I'll use a Rivnut - πŸ‘πŸ‘
1976 Yamaha RD 400C
Post #1041827 4th Aug 2024 2:09pm
excossack
I put a small fuel tank under the bonnet and mounted the pump to the inner wing 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #1041902 5th Aug 2024 8:17am
MarkBrown
I mounted mine on the floor behind the front seats bulkhead. There’s a t piece to direct heat to the front, between the seat and cubby box and on to the back. The pipes go through the floor, there’s a chassis rail nearby to mount the pump, the fuel line on mine is routed across the chassis, so nearby. Exhaust exits underneath but towards the outside, fixed to the tub cross member. The breather is extended to draw air from the bulkhead under the bonnet.
Post #1041909 5th Aug 2024 8:54am
Evil Elsie
Thanks Gents - some further food for thought there...πŸ‘πŸ‘
I've bitten the bullet and ordered a Mud Stuff Heater Box. I'll fit the heater then see where everything lays and take it from there.
I was overthinking it - My spaghetti brain was just picturing my heater sat on top of a pile of spaghetti.... πŸ˜„
Thanks to all. 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1042045 6th Aug 2024 9:14am
sako243
An alternative which FridgeFreezer on Lr4x4 has done is install a 3l catch can on the return line (petrol though). Fuel from engine goes in top, return to tank comes out the top and the fuel heater pickup is in the bottom of the can. 3l is enough to run for about 48h on his Webasto. Doesn't have to bother with the fuel tank and to refill he just drives the vehicle. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #1042153 7th Aug 2024 10:10pm
Evil Elsie
Ooo, now that is a good idea..!!
Bloody hell - there's lots of good ideas with pros and cons for all.
Is there any love for simply fitting one of these fittings to/from the fuel tank Sender unit - or is it rubbish..??
https://www.ebay.co.uk/itm/355048999519
Cheers all πŸ‘πŸ˜πŸ‘ 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1042230 8th Aug 2024 2:44pm
