![]() | Home > General & Technical (L663) > Automatic headlights |
lightning Member Since: 23 Apr 2009 Location: High Peak, Derbyshire Posts: 3060 ![]() ![]() |
l guess not then. lt was worth posting just in case.
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2731 ![]() ![]() |
I’ve never had them come on when driving under a tree - it would need to be a decent length of dark/shade for that to happen.
BadgerWaz Member Since: 15 Jul 2024 Location: Somewhere else Posts: 110 ![]() ![]() |
Can't you turn off the auto/on setting in the pivi?
Also if the car in front stops because they think you've flashed your headlights I'd suggest extending your middle finger as you pass ![]() |
l don't know, can you turn it off? Won't it just turn itself back on like the stop/start
Hairy Dan Member Since: 25 Apr 2013 Location: NW Durham Posts: 1443 ![]() ![]() ![]() |
Didn't you post a very similar thread a while ago? Cheers Ian
-------------------- 22MY Defender 110 D200 SE, Fuji White. Kielder 4x4 Safari Instagram @defender_v8 |
Do you have a GAP 4? If not I can sit and scan through the 1000+ list of codes and let you know. There are a lot of lighting options so at a guess I'd say you could turn auto high beam off permanently. I'll be turning off the unnecessary brake assist, twice now the car has slammed on and swerved the steering as we've driven around bends with parked cars on them (at the roadside on the bends). Ridiculous. |
Same here, with me it was when l am waiting in the middle of the road to turn right, and a gap in the traffic appears.
l turn and the Defender decides there isn't enough space and slams on the brakes, nearly causing an accident l've got the GAP 3 currently. Keep meaning to send it back in exchange for a version 4. I would happily turn off the automatic lights or at least make it an option like it is on our Suzuki Jimny. Somewhere it will be possible to calibrate the sensor and one option would be to reduce the sensitivity so the lights only come on automatically when it's actually dark. As you already have the DRL's on all the time anyway. However it has saved me on one occasion when l turned into an entrance and failed to see a low wall. The Defender stopped itself and there was no damage. Except it was that close, when l reversed it pulled the lower front corner trim off. Fortunately the part only cost £85 and was easy to replace. |
