Home > Technical > Brakes need pumping all the time
JulieG
So this is a struggle.
I fixed the three amigos around 10 years ago with the bypass mod, but it went wrong again, this time the error was a pump fault, and sending the ABS modulator away confirmed it was faulty and non-repairable.
So I got a fully reconditioned unit, fitted that - sorted the problem, but I now found the brake pedal would slowly go to the floor.
So replaced the master cylinder with a new one, which has sort of fixed it.
However there is a new problem, press the brake pedal and it goes almost to the floor, pump it once or twice and it goes solid (well defender solid anyhow).
Sit there several seconds to a minute and again the cycle repeats - pedal goes to the floor, one or two pumps and back solid.
Importantly, the vehicle is not moving, just stationary whilst we find the problem. A few years back it had stainless braided hoses fitted all round, it had the front pipes replaced and new pipes all around at the calipers.
It has been pressure blead (several times now) including power blead through the modulator, no leaks anywhere.
I can't find how to solve this at all, the master cylinder has been changed, no driving, so not wheel bearings, when it goes solid, it's more solid than ever before, all new brake fluid, no air bubbles and the fluid isn't going down .
Totally stuck
Any ideas guys?
Post #1040940 25th Jul 2024 7:11am
JulieG
OK, found the problem!
In the brake servo, there is the plunger/rod that goes into the master cylinder - it is this that drives the piston.
It's held in place by a star washer/clip - turns out this was loose - so as the engine runs, the vibration causes the plunger/rod to shift about pushing the master cylinder piston down a little, leaving a gap between the plunger/rod and piston or diaphragm - thus after a bit when you press the brake, it has to take up this gap before it starts pushing the piston.
I used a bit of tube, pushed the washer/clip hard into place, with the plunger/rod now fixed to the diaphragm it doesn't produce any gap.
Took some finding!
Post #1041575 1st Aug 2024 1:14pm
landy andy
Great work Thumbs Up Thumbs Up
Did you disconnect and remove the master cylinder to do this.
Post #1041577 1st Aug 2024 1:31pm
JulieG
Yes, it's a bit of a pain, because with the ABS modulator there isn't enough flex in the pipes, so it has to be removed completely (Inc bleeding the brakes etc).
You have to adjust the length of the plunger/rod to match the new master cylinder anyhow.
So you end up removing and replacing it several times too long and the brakes lock on - unable to release, too short and there is excessive travel in the brake pedal.
Post #1041581 1st Aug 2024 3:18pm
landy andy
Thanks for that info. Thumbs Up
Post #1041589 1st Aug 2024 6:13pm
jst
You can adjust the servo rod without completely removing the master cylinder. Undo the bolts from mc to servo and ease it forward. Depress the brake pedal so plunger/rod is protruding and then adjust. Its tight but doable, at least on the defensersninhave had. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #1041616 2nd Aug 2024 5:17am
