Home > Maintenance & Modifications > Mud Stuff Heater Box
Evil Elsie
United Kingdom 2002 Defender 110 Td5 HT Alpine White
Hello,
I've just bagged myself a used Eberspacher D1 diesel heater. I had a bit of a search on this wonderful forum for 'installation ideas' and saw the Mud Stuff Heater box.
This is an ideal solution - apart from the bloody price 😬.
As it sits below the cubby box it raises the cubby box height by 140mm.
Can anybody that has a raised cubby box (for whatever reason) tell me if this extra height makes it awkward to shift between High and Low on the T/box..??
With the aid of a steel rule and my imagination (not my strongpoint) it looks like it might...
As always, many thanks.
Dave 2002 Land Rover 110 Td5 Utility
1990 Suzuki GSXR 1100L
1980 Yamaha RD 350LC
1976 Yamaha RD 400C
Post #1041187 28th Jul 2024 4:33pm
Bill1919
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Corris Grey
Yes, the extra height was a bit uncomfortable for me, so I cut about 10cm of the sides the box and using the old hinges and catches made a new lid. Depending on what box you have, you should be able to peel back the side coverings and reuse. New covering only needed for lid.
 1988 110 csw 2.5Td (19J) (gone)
1992 110 csw Tdi200 (gone)
1995 110 csw Tdi300 (gone)
2015 110 XS csw 2.2 puma
Post #1041197 28th Jul 2024 5:48pm
Zed
That’s a neat solution. Nice work. WARNING.
Post #1041200 28th Jul 2024 6:23pm
Evil Elsie
Yes, a lovely job and thank you..😁
It does, however, make the thought of spending almost Β£100 on a small metal box that I then have to 'modify' even less palatable.... πŸ˜€
Nothing's ever easy or straightforward, is it..??
I really wish that I'd cut my Bulkhead down a bit now, like I WAS going to. I could have moved both boxes back a couple of inches....
Oh well, there's probably a lesson in there somewhere....
Thanks again,
1976 Yamaha RD 400C
Post #1041202 28th Jul 2024 6:36pm
s55shh
it can be awkward if you have water/coffee in the cup holders. But I've got used to it
Post #1041242 29th Jul 2024 9:07am
Evil Elsie
Thank you...πŸ‘πŸ‘
I guess the compromise is worth it.
Staying warm every time I drive in the Winter vs a little awkwardness on the couple of times we go out Green laning per year.
Thanks for the responses.
Dave. 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1041243 29th Jul 2024 9:20am
Cragster69
Scotland 2007 Defender 110 Puma 2.4 CSW Cairns Blue
I have the Mud under cubby Sub Locker and it after installing it was awkward changing gear if I had a water bottle or a coffee cup in the holder.
Ended up having to swap it about from one side to the other when driving stop start for 1st into 2nd or A roads 5th to 6th.
After our holiday I decided to modify the cubby box to move it back by drilling new holes, only after drilling the new holes did I realise that the lid on the sub locker is offset and turning it 180 degrees it fits better, the cubby slightly overhangs into the middle row, but it doesn't get in the way when changing gear. Craig.
β€œDon't believe everything you read on the internet.” ― Abraham Lincoln
www.scotgrc.co.uk
Post #1041251 29th Jul 2024 10:31am
AMBxx
I found that on the Puma, the cubby was in the way of the range selector even before I installed an under-cubby safe.
Solution was to move the safe & cubby back a bit and find some lower cups for the cupholder.
Post #1041255 29th Jul 2024 11:46am
Evil Elsie
Thanks again for the various responses. There's definitely a recurring theme here... πŸ€”
I was baulking at paying Β£100 for a small metal box and I really am now that I know I'll have to get 'modifying'. Are there any other alternatives..??
Where's Britpart when you actually need 'em..?? πŸ˜€ 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1041275 29th Jul 2024 2:59pm
Retroanaconda
I think Bill1919 modified the LR cubby box, not the Mudstuff one.
Post #1041299 29th Jul 2024 7:53pm
Evil Elsie
Hmmmm....interesting..!! Thank you for that. I shall send him a message.
Cheers 😁 2002 Land Rover 110 Td5 Utility
1976 Yamaha RD 400C
Post #1041348 30th Jul 2024 10:15am
