![]() | Home > Puma (Tdci) > Rear door fit. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17725 ![]() ![]() ![]() |
I'm guessing that you mean second row door rather than rear door, since you mention the gaps at front and rear.
The photo below shows the typical panel gap on a second row door, this is an ex-factory Puma. I'd say the one you describe is actually unusually good. ![]() |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 934 ![]() ![]() ![]() |
Could have had new hinges or something and not aligned tidy? Easy to sort. 2008 2.4 110 Utility Station Wagon XS.
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4784 ![]() ![]() |
Hand built, will not be perfect. My 2011 has a little discrepancy in the same place. It is just that when the panels were riveted together the one on the right was not close enough to the one on the left. Every craftsman has an off day! 1982 88" 2.25 diesel
