![]() | Home > Puma (Tdci) > Puma 2.2 throttle issues |
andy63 Member Since: 30 Jun 2023 Location: north east Posts: 388 ![]() ![]() |
Hi.. Each potentiometer on the acc pedal will have it's own supply and earth along with a signal wire who's voltage varies as you depress the pedal.. All need checking to verify or confirm the fault code as been due to a faulty unit..
If the abs light is on there should be a code for abs, which a generic obd reader won't see.. Check the function of the two brake pedal operated switches.. One does put a supply to the abs control module, but ideally you would check for the generated code with a suitable tool.. |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20033 ![]() ![]() |
There does seem to be a bit of a pattern with this with 2.2’s, I seem to remember similar issues of this nature with three or four posters on here in the last couple of years. Diesel$ Live$ Matter. ⛽️🛢️👨🔧🧰⚙️ RED, WHITE & BOOST! 🇬🇧
CornishLandys101 Member Since: 27 Jul 2024 Location: cornwall Posts: 2 ![]() ![]() ![]() |
cheers genets appreciate it I'm great mechanically but the electronics might be a bit to much and a Landy specialists job, I'm goanna swap my dads throttle pedal from a 2.4 over it seems ok for now.
do you know what people with this issue before have done to resolve it? |
If you use the search function on the above bar you should be able to find some info I would imagine from other posts.
Also welcome to the site. ![]() ![]() |
