![]() | Home > Puma (Tdci) > Dent in intake tube pre manifold? |
Fernando Member Since: 25 Oct 2017 Location: CABA Posts: 93 ![]() ![]() ![]() |
Seguro es justo donde esta el tornillo de la abrazadera, el mio esta igual.
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
En serio?
Capaz que no sea entonces la causa de mi problema. ![]() Así se ve una nueva por ese lado por lo menos. ![]() Click image to enlarge Puma 110" SW ............................................................. Earth first. Other planets later |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20650 ![]() ![]() |
I would imagine caused by an over tightened clip possibly. Unless a large ratchet hit it. TheThunder Rolls🇬🇧🇺🇸
Exactly. But I dont see how overtightening would cause this. However it matches the likely position of the clip adjuster.
So far hoses and intercooler are tested up to 18 psi. Going for the manifold now. Puma 110" SW ............................................................. Earth first. Other planets later |
