![]() | Home > Maintenance & Modifications > should i upgrade headlamps |
adafish Member Since: 30 Mar 2009 Location: atherstone Posts: 1387 ![]() ![]() ![]() |
............YEP.... we sell alot.....i have a set in my 110 DC , even on dip beam, i can see better than before than Hi beam ( 4 roof rack mounted spot lights ) Putting Dreams on Drives at JLR Solihull.. |
.....watch www for more info, coming in New Year... Putting Dreams on Drives at JLR Solihull.. |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
[quote="richuk"][quote="ZeDefender"]
DefenderOfTheEarth Member Since: 09 Nov 2010 Location: Cornwall, UK Posts: 1304 ![]() ![]() ![]() |
For a complete DIY spanner like me, any links to the Wipacs/bulbs and can my local garage fit them?
Could be interested in the LEDs too. Possibly... Any links?! Defender 110XS SW gone... now VW California 180 4 Motion. |
richuk Member Since: 13 Nov 2011 Location: Dorset Posts: 201 ![]() ![]() |
No problem Bulbs here http://www.amazon.co.uk/gp/product/B00440CWBW Although I just noticed they have gone up 2 quid since last week, so maybe cheaper elsewhere. Wipac Crystals Here http://www.paddockspares.com/pm678-wipac-c...ralia.html Rich semper in excretia sumus solim profundum variat |
Rich the Speaker LED lights are dead easy to fit, might be worth buying somemore headlight rings to...The new headlights are just plug in..... www.mobilecentre.co.uk Putting Dreams on Drives at JLR Solihull..
You're a star! Think I'll grab some and get HiQ to fit them. Cheers! ![]() |
Aaarghhh - SO tempting ![]() Only worry is if one dies after guarantee (3 years?) - very expensive to replace... The ones I'm looking at are here: http://www.ebay.de/itm/290637702882?ssPage...1438.l2648 Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
scottish110 Member Since: 10 Nov 2011 Location: Inverurie Posts: 363 ![]() ![]() ![]() |
Found these.... Would be interesting to see some pics. i'll email today and post when i have pics from them
http://www.brittle.co.uk/news/military-sty...e-systems/ |
More than likely JW speaker ones (Same as mobile centre ones)
@ KEN....
Sorted I got a fibre glass one
twopoint6khz Member Since: 18 Aug 2011 Location: North Lakes Posts: 655 ![]() ![]() ![]() |
Fitting WIPACs and bulbs can be done with one screwdriver - it really won't take you long. Procedure is:
Sidelights and indicators off (unscrew) Headlight trim panel off (2 screws) Headlight unit out (4 large screws at 2, 4, 8 and 10 o'clock - don't drop them into the bodywork!) Levelling ring off (if fitted - no need to touch screws as the holes are slotted, just pull them out sideways) Disconnect levelling motor (if fitted - push clip) Bezel off (3 small screws holding clips, probably very rusty) Rubber cap off back of bowl (pulls off) Then fit the new bulb to the new bowl and reassemble. In the finest Haynes manual tradition, assembly is the reverse of disassembly ![]() |
Def-00 Member Since: 11 May 2011 Location: Sharjah Posts: 236 ![]() ![]() ![]() |
Fitted the 8700 today, huge difference from standard lights
![]() ![]() ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() ![]() Last edited by Def-00 on 22nd Dec 2011 10:49pm. Edited 1 time in total |
