![]() | Home > Faults & Fixes (L663) > Front parking sensor fail |
Nitroneil Member Since: 05 Mar 2019 Location: Stirling Posts: 132 ![]() ![]() |
Looks like I will booking mine in to get them to look at sensor problem, all but the rear not working. But now got security updates to do as well so guess its worth a call. 90S D250 fuji and loving it.
Lockley Member Since: 15 Feb 2023 Location: Herefordshire Posts: 16 ![]() ![]() |
See my post above. I’ve now booked mine in at the dealer to be looked at under warranty and have the security updates done at the same time.
In the meantime, my gap tool has thrown up an error code related to the front left parking sensor. The dealer explained if one sensor goes out the whole front (or rear) parking aid is deactivated. L663 D300 SE MY22. |
XplusYplusZ Member Since: 16 Aug 2021 Location: UK Posts: 522 ![]() |
Mine's started doing this too. Solid red lines around front and sides of pivi parking display. Allows me to get mighty close to objects in front. Rears work ok.
Any updates on the resolutions? |
Mines in garage just now, seems to be a front failed sensor after all, although rear parking sensors still working as they should. 90S D250 fuji and loving it.
Gareth Member Since: 12 Dec 2011 Location: Woodford Posts: 1118 ![]() ![]() |
Mine had this last January. It was fixed by the dealer just outside of warranty.
Unfortunately it’s just happened again. Not sure they will do a second fix under goodwill. Especially when I ask for goodwill on the very expensive matrix headlight that has failed drl and halo! 2021 Defender 110 X-Dynamic HSE D300 MHEV 1966 S2a 109 aka Betsy |
My front left sensor was faulty and was just fixed under warranty. I wonder if it might have been why my stupid car kept jamming on the emergency brakes without anything in front of me...
Moo Member Since: 01 Oct 2021 Location: UK Posts: 1446 ![]() ![]() |
I've often wondered whether we should use the Consumer Rights Act more with LR.....
https://www.which.co.uk/consumer-rights/re...JYx8n5KiSl With the number of fails being reported and repair kits available from third parties, it would suggest that this is a quality issue. Eiger Grey MY23 D250 SE with bits. Known as Noddy. |
Mukafuka Member Since: 28 Dec 2022 Location: New york Posts: 6 ![]() |
has an official fix been found for this? Im pretty sure my sensors are all fine (placing my finger on the sensor, I can feel all of them 'tapping" and the sensors will spontaneously start working from time to time.
Freddy801 Member Since: 01 Oct 2024 Location: Virginia Posts: 4 ![]() ![]() |
Hi All,
Just wanted to throw this into the discussion. I recently did some off roading so I aired down the tyres to 20 psi and had some fun in the sand. When I aired back up to road pressures, I discovered my parking sensors no longer worked - I had a full red box around the cameras. I assumed it would clear itself after they had dried out and I washed the car. The fault didn't clear so I took it to my dealer. It turns out the fault was due to the over-pressure of my tyres (the compressor gauge was faulty so I accidentally aired them up to 57 psi!) Once I reduced the pressure, the fault cleared completely and I had parking sensors again. Believe it or not, this is actually documented in the i-Guide too! Just a suggestion and I hope you get the problem fixed. |
