![]() | Home > Puma (Tdci) > Thank you |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20650 ![]() ![]() |
Bear in mind the VCV when replaced doesn't need learning or programming.
It will shortly self learn by itself. (Just posting this, as it can often be unknown by those who may want to replace their VCV). TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
hornet Member Since: 04 Jan 2010 Location: Western Europe Posts: 362 ![]() |
I would start disconnecting the plug from the MAF first and see what happens, replacement values will then be used. |
land 0068 japan Member Since: 27 Jun 2024 Location: kanagawa Posts: 11 ![]() ![]() ![]() |
I replaced the air mass sensor (MHK501040) and MAP sensor (LR022164), but the symptoms did not change. What else could be the cause? In the end, the EGR (LR006650), main computer, and security box were the three main problems. |
Today, I replaced the main computer and security box (green) parts and test drove the car, but the symptoms did not change. I replaced the air flow sensor with a new aftermarket part (made by Intermotor) and the MAP sensor with one from another vehicle, but the symptoms did not improve. I cannot find any more parts to replace. Is there anything else I can think of that might improve things?
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2456 ![]() ![]() ![]() |
So, you still have the very same symptoms? What are the DTCs? Puma 110" SW
The details of the symptoms are: water temperature 90 degrees, when I press the accelerator pedal all the way to accelerate, the engine will choke for a moment. Even after that, when I try to accelerate, the engine chokes intermittently and stalls. The engine check light is not on, and there are no fault codes as far as I can see with a tester.
I've replaced and cleaned all the fuel system and sensors, but the symptoms have not improved at all. Excuse me. What does DTC mean? |
