Home > V8 > Engine stalls
NineT
Engine stalls
Out at the weekend and the 90 started to cut out, immediate loss of power and revs to zero, not like running out of petrol. Stopped, and then re-started 1st time only to repeat 4X on the way home (10 mins drive). Has anyone had this happen to them?
Post #1040841 23rd Jul 2024 6:43pm
Mdm
would help folk if you told us what model 90 it is? tdi td5 puma?
Post #1040858 23rd Jul 2024 8:57pm
TexasRover
Well it's in the V8 forum.
Revs dropping to 0 fast on the rev counter indicates ignition issues I would start there. What is 3.9 GEMS?
Post #1040864 24th Jul 2024 5:18am
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
Carb or injection?
As above, it sounds like it could be electrical if the engine is cutting out but will re-start.
It could be a breakdown of the ignition when under-bonnet temperatures are high. I had this on an 80”. Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #1040865 24th Jul 2024 5:26am
NineT
Thanks for the responses.
It’s a 4.0 Gems v8 auto, 90
Post #1040972 25th Jul 2024 2:48pm
discomog
Question - have you had the vehicle a long time or have you just acquired it. The Lucas-Sagem GEMS ECU is quite a complex system. Has it been rechipped at any time? If the ECU has been rechipped in an attempt to "hide" a fault it will try to compensate for this but could well cause other faults to develop.
With the engine warm if you start the vehicle, watch the idle speed -is it normal or slightly high? If it is slightly high and then drops back to normal, this is the ECU sensing a fault and then setting the best idle speed to compensate for any fault. If this happens the fault is likely to be within the ECU. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #1041028 26th Jul 2024 10:17am
NineT
Hi Discomog,
I’ve had it some some time, 4+ years. I’m not aware of it being chipped, it was not sold as chipped.
I’ll watch the idle speed this weekend when it’s warm. If the fault is with the ECU are there specialists who can repair? Thanks
Post #1041030 26th Jul 2024 11:29am
discomog
ATC Drivetrain UK, Bluehawk Electronics and RPI Engineering. I've not used them but these are companies that I know a number of Morgan Plus 8 owners have used for ECU testing and repair. Defender 90XS SW
Morgan Plus 8
Post #1041042 26th Jul 2024 2:08pm
Rupert605
United Kingdom 1998 Defender 90 V8 Petrol 50th Auto Atlantis Blue
Do you have access to a Nanocom to check for any fault codes? Where are you based? Defender 50th GB165
Discovery 200 Tdi 1990 (gone)
Post #1041108 27th Jul 2024 10:40am
TexasRover
NineT wrote:
Hi Discomog,
I don't know about the GEMS (I have a P38 4.6 with the Bosch system), but I would suspect your ignition coils before the ECU.
Post #1041111 27th Jul 2024 11:46am
chazza
Best person to solve GEMS issues is Mark Adams at Tornado Systems. You can buy cheap OBD2 scanners these days that will help with diagnosis rather than just changing parts and hoping for the best.
Post #1041626 2nd Aug 2024 8:03am
