Home > Puma (Tdci) > Problem: Hand brake, ABS, TC lights illuminated, over rev..
Robotmatt
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Problem: After starting, handbrake, ABS and Traction control lights all illuminate (after going out), engine automatically revs slightly on gear change!
Anyone had this before? It was intermittent, how happens every time. I Suspect a failing sensor or switch...
Will report back findings... and hopefully fix! Any clues where to start??
2.4 tdci 2010 90
Post #1040784 23rd Jul 2024 8:08am
Swollock
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Bonatti Grey
I had this recently, a code reader would be a great help to find the problem. My problem was the power wire to the ABS pump which had worn through as it was touching the back of the brake servo, ground out and blown the fuse under the drivers seat. New fuse and wire repair it was all sorted. 2008 Defender 110 XS CSW
Volvo S60 T8
Triumph 1200 Rally Explorer
G0UBX
Post #1040792 23rd Jul 2024 8:45am
BrickBox
Check your rear brake lights are all working - if not, that’ll be your Rev hang problem. 2008 2.4 110 Utility Station Wagon XS.
Post #1040795 23rd Jul 2024 9:24am
Failed clutch switch, you can buy a connector 2 pole JPT and bridge it.
If it is that, it will fix it straight away or you can get a new clutch switch.
There should be a DTC logged though, but won’t illuminate the MIL.
It creates a sort of power surge just when put in gear, it is very stange and feels like it is self reving.
This is based on what I’ve had happen before, and matches the symptoms you mentioned. TheThunder Rolls🇬🇧🇺🇸
Post #1040848 23rd Jul 2024 7:33pm
