![]() | Home > In Car Electronics > Defender AC condenser fan plug? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6560 ![]() ![]() ![]() |
On the fan itself or on the engine loom?
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2123 ![]() ![]() |
Both ends! Wanting to make a split off cable to have a manual over ride. Instagram @defender_ventures
Empire Tuning - Agent |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 ![]() ![]() ![]() |
They're BMW connectors.
The 2-way female connector (engine harness, C0280) - 61138352390 Female terminal (1.0 - 2.5mm²) - 61131392304 Wire seal (1.0 - 2.5mm²) - 61131383791 Or, pre-crimped with a seal to a length of cable - Socket terminal circular 2.5 ELA with wire 1.0 - 2.5mm² - 61130007571 ![]() The 2-way male connector (fan tail) - 61138352391 Sealed male terminals appear to be only available pre-crimped with a seal to a length of cable - Round plug-in contact 2.5 ELA with cable 1.0 - 2.5mm² - 61130007572 ![]() . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Engine loom side plug (female terminals): LR YPC110330. Cheaper than BMW part.
Fan side socket (male terminals) BMW 61 13 8 352 391 All terminals (male and female) and seals from me ![]() ![]() ![]() |
Ahhh thank you martin! Insaw the price of the above ones and thought screw it ill just replace the lot with DTP connectors.
Should have been a bit more patient ![]() Thank you though! Instagram @defender_ventures Empire Tuning - Agent |
