tooth_dr wrote:
I’ve just installed ACC on the car, but notice now my wing mirrors aren’t folding on locking. Does that mean it hasn’t worked properly or something else?
same , did you sort this?
8th Mar 2024 12:50pm
defending
Anyone managed to fix the park assist grey out start button issue ?
17th Jul 2024 11:43pm
JonathanP
I have the same problem re the park assist greyed out start button issue,. The system will look for a parking place, miss quite a few, the Start button does not work, and I can not switch it off?
18th Jul 2024 10:31am
alamri666
DefenderMidlands wrote:
After changing CCF files or updating scripts to clear brake error YOU HAVE TO go to Main menu, select DADC module from drop down list, then click on CCF memory and select 'DADC-DriverAssistanceDomainController Learn vehicle configuration (as in the picture) and do the same with the IGM module relearn both of them (picture shown below)
After check DTC, clear DTC on both modules, lock car and leave to sleep for 10 minutes and it will work (this info is from GARY at autosvs)
I have used this software before; yes, after any change, it is recommended that you follow these steps.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
