Home > Technical > 15A fuse F29 keeps blowing on '63 110 XS
rotters-uk
Last couple of days my hifi and clock has stopped working and the tripmeter always reset to 0 when I start the engine. I noticed fuse f29 has blown and keeps blowing if I try to replace, even with ignition off.
Anyone any suggestions why and how to fix?
Post #625056 18th May 2017 9:24am
dorsetsmith
F29 feeds (10 Amps)
diagnostic socket Embarassed
instrument cluster
clock Analogue
Radio CD player
Lamp interior
you have short cct blowing your fuse
check all above
Post #625065 18th May 2017 9:51am
rotters-uk
Thanks for the information, that makes sense.
How do I work out which of these components is causing the problem? The fuse on the radio is ok so I assume it is not that, do I need to take out the clock etc?
Any suggestions greatly received!
Post #625076 18th May 2017 10:16am
dorsetsmith
by isolating items you can find problem
Post #625077 18th May 2017 10:19am
rotters-uk
Ok, so I have isolated the radio, internal lights and analogue clock but fuse still blows. If I remove fuse FL5 from under the seat it doesn't but as soon as I reinsert the FL5 the F29 blows.
You said instrument cluster - how do I isolate that??
Post #625139 18th May 2017 2:57pm
Leviathan
Personally I would first trace the wires to the diagnostic socket and see if there's any shorting/pinched wires in that.
Post #625166 18th May 2017 5:39pm
rotters-uk
Thanks for the suggestion. I will try that today.
Do I need to remove the dashboard facia to do this?
Post #625303 19th May 2017 7:21am
xpertoftheseas
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Aintree Green
Take a look at this....
If you pull FL5 (Fusible Link) this feeds F29 which in turn feeds the instrument cluster. This is a keep-alive for the cluster, so explains why your trip meter is always at zero when you start as the IGN is lost when you stop the engine. The bad side of this is that the instrument cluster feeds a load of inputs and outputs and you will need to identify each one - some of these are...
Heated Front screen timer
Handbrake Switch
Reverse Lamp
Hazard Lights/Indicators
Can Bus
Hi/Lo Range
If you need some drawings let me know. I would suggest pulling out C1040L connector from the back of the instrument panel and getting a multimeter ready. Open up the Electric Reference library....
...and the wiring diagrams, and identify each of the above outputs. With the exception of the CAN bus lines, you should be able to check each output to see if any are short to -ve.
Of course, the instrument cluster itself could be faulty but unlikely. It will most likely be one of the outputs which heads underneath the Defender and is chafing or a connector full of crud. These sorts of faults are just a process of elimination. Hot cup of tea, laptop with the drawings, a multimeter, pen and paper and patience. You will find the culprit.
Here to help if needed. I am free this weekend so if you need some talking through let me know. My 10th Land Rover, but my first Defender.
Post #625512 20th May 2017 1:04am
rotters-uk
Thanks for the advice expert, I will have a go at this today and let you know how I get on...
Wish me luck!
Post #625560 20th May 2017 9:48am
rotters-uk
Ok, am I being really stupid?
I have just disconnected the C1040L connector on the back of the instrument cluster and before I start trying to trace a particular problem component I decided to replace fuse F29 to check this is where the problem is. However, the fuse blew again as soon as I tried to insert!?
So I now have my clock, radio, internal lights and instrument cluster all disconnected (which I assumed would prevent the sort circuit) and the fuse keeps blowing?
Am I missing something obvious??
Post #625576 20th May 2017 11:59am
Balvaig
Not stupid at all. Shorts are a nightmare to trace but you are narrowing down the area at fault. You look as if you have a short in the loom after the fuse. From reading the thread you have isolated everything except the diagnostic port and the loom. I think if you have the right gear you can test for a short without the fuse.
Never had to test a loom, but others with expertise should be able to advise.
Post #625579 20th May 2017 12:26pm
dorsetsmith
dorsetsmith wrote:
F29 feeds (10 Amps)
instrument cluster
clock Analogue
Radio CD player
Lamp interior loom run up driver side windscreen behind plastic trim
check all above
diagnostic socket (my mistake) its in under dash fuse box
Post #625590 20th May 2017 1:53pm
xpertoftheseas
Hi. PMd you also.
Although this may sound stupid, this is a good thing. What it means is that you have a cable fault in the loom between the fuse box F29 and the connector C1040L.
If you remove F29 (it's blown anyway but just in case) disconnect C1040L and get a resistance reading between pin 1 on C1040L and ground, this will confirm a wiring loom problem. If it is low resistance then you will need to trace the loom from C1040L back to the fuse box. The wire colour is brown I think (check the drawing I posted). If you need the loom routing let me know and I can post the drawings later). You need to look for any damage to the loom, chafing rubbing etc.
Good luck My 10th Land Rover, but my first Defender.
Post #625591 20th May 2017 1:55pm
^^^^ Sounds good to me. Thumbs Up
That connector has often had issues it's self.
Also, make sure the battery is disconnected when doing any work electrical.
Even testing you can cause more problems than when you start otherwise.
It maybe a pinched or chaffed wire, but possibly a short nearest the connector. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #625606 20th May 2017 4:15pm
Mauri_X
Italy 2007 Defender 90 Puma 2.4 SVX Station Wagon Santorini Black
same problem here now,
have you found the solution?
have you some advice ?
Thank you, thank you very much !!
Post #1040103 16th Jul 2024 5:00pm
