![]() | Home > Technical > Electric window switch confusion |
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 496 ![]() ![]() ![]() |
Sorry, I don't.
However, looking at one of the switches, it is made by AnSor and has the part no. 13E N 585 printed on it. AnSor are the OEM switch manufacturer for much of the Italian automotive industry, as well as aftermarket applications. 585 is listed on P.33 of their Windows Catalogue for VW Golf - ![]() Click image to enlarge The wiring tallies with the Britpart diagram - ![]() Click image to enlarge I found an Italian listing on eBay UK - https://www.ebay.co.uk/itm/266709881651 ![]() Click image to enlarge Also on eBay It - https://www.ebay.it/itm/265656594981 ![]() Click image to enlarge . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
robbie9999 Member Since: 07 Jun 2023 Location: Toronto Posts: 16 ![]() ![]() ![]() |
@Paul MC
This is why forums are so brilliant ! It’s people like you that go extra mile to help others ! Good man thank you I was banging my head against the wall, reached out to the company not sure why Landrover changed to five pin from a vw golf/ polo ordered two Cheers |
They didn't.
Your switch is from the aftermarket Britpart electric windows kit DA4664 The switches they've used in the kit are an aftermarket replacement for the VW switch - but using a different connector ![]() The genuine VW switch is identical to the Discovery-1 / late RR Classic window switch AMR2496 - and, it uses the same connector - https://www.defender2.net/forum/post987015.html#987015 . Paul. 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
