Home > Technical > Electric window switch confusion
wadaw
United Kingdom 2006 Defender 90 Td5 HT Belize Green
Hi folks, appreciate some advice relating to electric window switches fitted to my 90 TD5.
I can’t seem to identify if these are OE Defender switches or from some other LR vehicle ?
One of them no longer illuminates - is it possible to replace the bulb?
Appreciate the help.
wadaw
Post #986940 26th Mar 2023 8:20pm
PCM
Part number YUF101521LNF
Td5 and Tdci compatible plus free lander 1
https://www.mudstuff.co.uk/products/genuin...dow-switch
And other sellers
Post #986961 26th Mar 2023 10:10pm
wadaw
Thanks but the description says this is for a 6 pin connector, not the 5 pin connector my TD5 has - anyone know of any available that are a straight swap for the 5 pin ?
wadaw
Post #986965 26th Mar 2023 10:52pm
Dinnu
Used to have an old VW Polo, 6n1, with a switch that externally looked identical as the LandRover ones. However do not know pin layout.
https://www.autodoc.co.uk/car-parts/window...o/polo-6n1 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #986967 27th Mar 2023 4:02am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Looks like switch P/N AMR2496.
I don’t think the LED is available, just get a new one for around £10.
Post #986968 27th Mar 2023 4:36am
rallysteve
Discovery 1 switches look very similar to Defender ones but have 6.3mm spade terminals on the back rather than the in-line AMP connectors used on the Defender ones.
I used some on my TD5 retrofit originally. However the terminal layout doesnt look the same as the one you have pictured
Post #986981 27th Mar 2023 7:56am
PaulMc
The window switches in the OP's post, are from the Britpart electric windows kit DA4664
They are not the same as the 300Tdi Discovery-1 and RRC Softdash switch AMR2496 -
AMR2496 appears to be the same as the VW switch, and uses the same connector with 6.3mm Standard Timer receptacles -
. Paul.
Post #987015 27th Mar 2023 1:38pm
wadaw
Thanks Paul, very helpful . I think I’ll have to change to the LR 6 pin type, I cannot find just those Britpart switches outside of the kit…
Thanks for the help guys.
wadaw
Post #987017 27th Mar 2023 3:00pm
PaulMc
I've got a couple of the Britpart switches - brand new and unused.
I fitted a couple of these Britpart window kits and used Land Rover switches (YUF101521LNF) with them.
If you want them - £10.00 each + £4.65 for 1st class small parcel P&P
. Paul.
Post #987018 27th Mar 2023 3:14pm
wadaw
Thanks Paul, I’ll drop you a PM
wadaw
Post #987029 27th Mar 2023 3:59pm
ASBGuernsey
Guernsey 2012 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Hello Paul MC,
I am a new user here. I am looking for the Britpart 5 pole switches for a Defender 90 Truck Cab that was converted to Electric Windows from Manual winders. One of the switches is no longer working, and I cannot find a replacement 5 pole switch anywhere
Are you still able to assist ? As a new user I am not allowed to PM you until I have posted enough messages !
Thank you
Andrew
Post #1039960 14th Jul 2024 9:30pm
PaulMc
Hello Andrew,
I still have a pair of these switches - brand new and unused.
The price for the switches is £10 each, I'll have to check what RM are now charging for postage.
To increase your post count, go to https://www.defender2.net/forum/topic233.html and introduce yourself.
Or, go to https://www.defender2.net/forum/my-defender-vf4.html and tell us about your Defender.
Cheers,
Paul. Paul.
Post #1039963 14th Jul 2024 9:42pm
ASBGuernsey
Thank you Paul !
I will get my post count up, and then send you a PM. Please hold these 2 switches for me. I will send you a UK address in my PM that I will be able to collect them from in a few days.
My Defender TdCi in Portugal was converted with the Britpart kit. The other day the switch started smoking when activated, and I think this is due to the resistor that drives the LED for the green lighting. I cut off the LED and resistor, and the switch started working again, however it has now stopped lifting the window and only activates the lowering side of the switch. I presume this might be a wiring issue ? The rubber grommet on the door side carrying the central locking and window activation wires is not seated in the door card, and I am trying to find some pictures of how this should seat.
I would also like to replace the wiring between the body and the door, since I think there might be a break in a wire. If I jiggle the wires, the switch activates the window up.
Any idea of the correct gauge of wire to use here ?
Thanks
Andrew
Post #1039967 14th Jul 2024 10:17pm
ASBGuernsey
Hi Paul MC
I tried to send you a PM, please let me know if it arrived ?
Thanks
Andrew
Post #1039978 15th Jul 2024 7:13am
PaulMc
Hi Andrew, I've got your PMs Thumbs Up
I'll reply shortly.
Paul. Paul.
Post #1040003 15th Jul 2024 11:04am
